Old 07-13-2000, 04:57 PM
nemnemnem nemnemnem is offline
Default Where\'s My MTP/II (Via Keyspan twin..)??
Hi
G3/400/OS 8.6
PT 5.0/d24/882
OMS 2.3.8
QT 4.0.1
MTP II
Keyspan Twin serial (Control Panel 1.6)
OMS won't recognize the MTP
Which drivers are needed for this to work?
i know this issue has been discussed before,
but i can't seem to find the thread
there's a list of extensions for this setup to work
many many thanks, Nem
nemnemnem
Old 07-14-2000, 08:44 AM
dbullard1 dbullard1 is offline
Default Re: Where\'s My MTP/II (Via Keyspan twin..)??
My recolection is that the Keyspan won't support MIDI at all. You will need a stealth serial port that you install inside your machine in place of the modem.
Really easy to install, and easily purchased at outpost.com
Good Luck
David Bullard
Masque Sound and Recording
Old 07-14-2000, 09:53 AM
DigiTechSupt's Avatar
nemnemnem
MIDI using the keyspan is not supported
with Pro Tools or OMS. The Keyspan USB to
serial is only supported with Machine Control.
Please see the compatibilty docs: http://www.digidesign.com/compato/index.html
MJ
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
003 With UA 710 Twin-Finity OR Mbox 2 Pro with With UA 710 Twin-Finity samcharles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-05-2011 12:06 PM
"New" twin 1 Giga or "old" twin 1Giga digigirly Pro Tools TDM Systems (Mac) 6 09-24-2002 12:07 AM
OMS, Studio 3 & Keyspan Twin adapter Tim Goodwin MIDI 0 09-14-2001 01:07 AM
Digi- Keyspan USB Twin Serial Adapter + Machine Control Samhein Pro Tools TDM Systems (Mac) 0 06-29-2000 12:16 PM
Keyspan Serial Adapter or Keyspan Twin Serial... J. S. Bach General Discussion 0 03-20-2000 10:34 AM
