Outboard compressor with M-Powered + FW410
Hi, maybe someone can help me out with this.
I've got hold of the FMR Really Nice Compessor, but I'm having trouble figuring out the correct way of patching it in to my set-up. For example, I wanted to use the sidechain input on a bass track, so I put a send on the kick track using an Output on the interface, then patch the cable from that output to the compressor. Then I run the bass track through the compressor by setting the bass track's output the an ouput on the interface and cabling that to the compressor input....and now need to get the compressor output back into Pro Tools...but can't. Anybody use the RNC with the FW410, or have any ideas on the right connections to make? Thanks |
Re: Outboard compressor with M-Powered + FW410
Sounds like you need to play the track, send it out one of the outputs on the 410, adjust the compressor settings as needed, and then go back into one of the inputs on the 410 and record the compressed audio to a new track.
J |
ProTools M-Powered with outboard compressor | cjs102460 | Pro Tools M-Powered (Win) | 3 | 04-26-2010 09:41 AM |
Outboard Compressor...Help! | funkyghoul | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 08-12-2005 10:03 AM |
Outboard Compressor...Help! | funkyghoul | General Discussion | 4 | 04-24-2005 10:46 AM |
Outboard compressor? | where02190 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 12-13-2002 06:27 PM |
using outboard compressor with 001 | bigfrog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-21-2002 12:43 AM |
