Old 03-20-2001, 06:31 AM
tchipman tchipman is offline
Default Alesis SR-16 with 001
Hello
Is anyone out there using the SR-16 drum machine with the 001. I'm having trouble getting it to work right in MIDI. Any help would be appreciated.
tim
Old 03-21-2001, 03:46 AM
IOP Drummer IOP Drummer is offline
Default Re: Alesis SR-16 with 001
Make sure that the SR-16 and PTLE MIDI track are on the same channel/port. If using the sr-16 to sequence, make sure that THRU is OFF. If thru is on, then the only info at the MIDI out port is what's CURRENTLY at the MIDI in port. Record enable the track, and all should be good. If not, then you changed some things around that shouldn't really be changed unless you know what you're doing. Good Luck
Mike Blanchard
Engineer
Old 03-21-2001, 04:53 AM
Thanks drummer! I sent you a message on e-mail. Digi should really pay some of you guys who know all this stuff!
tim
Alesis DM5 and SD2 Hamdi The Drum Room 1 04-05-2011 09:52 AM
888/24 vs Alesis AI-3 smack Tips & Tricks 2 03-25-2003 07:07 PM
Alesis Ai3 Datus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-19-2002 07:34 AM
alesis ai3 stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-01-2002 04:32 PM
alesis qs6 hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-01-2001 04:06 PM
