Closed Thread
Old 05-23-2011, 07:26 PM
durak28 durak28 is offline
Default [SOLVED] Eleven Rack Noise Gate acting buggy
I'm controlling Eleven Rack with a midi controller in a live situation. The problem I'm having involves the noise gate of the amp (SL100) turning off between presets, even though the preset is built and saved with the gate "ON". The midi board is not sending any control change commands to 11R in regards to the gate. It appears to only occur when going backwards in the preset list. For instance going from preset Q3 to Q4 works fine but if I were to change from R2 to Q4, the stored gate on Q4 shuts off.
Anyone else experience this? I'm using a Skrydstrup SC-1 for the MIDI controller.
Thanks!
Old 05-24-2011, 02:36 AM
Default Re: Eleven Rack Noise Gate acting buggy
Dammit it's all my fault. Never mind, sorry. :)
Closed Thread
[SOLVED] FCB1010 Foot Controller (stock PROM) with Eleven Rack The Sentinel Eleven Rack 12 10-10-2018 12:18 PM
Eleven Rack Grounding? Noise RYOAK5150 Eleven Rack 22 12-03-2017 08:08 PM
SOLVED - Problem with the distorted sounds of the eleven rack! Koffax Eleven Rack 3 05-02-2011 10:30 AM
Noise from my brand new Eleven Rack zuriain Eleven Rack 4 02-01-2011 11:44 PM
Control 24 acting buggy w/ 7.1cs Spoonie June Pro Tools TDM Systems (Mac) 1 06-05-2006 10:32 AM
