003 rack+ sync indicators flashing
Mac OSX 10.6.2 snow leopard
PT 8.03 All three of the sync indicators on my new 003 rack+ are flashing and I cant get them to stop. Clock source is set to internal, I am using an octopre through optical as ADAT, but not as clock source. Indicators begin flashing on startup, before PT's is even launched. PT's is running ok, but with a small pop every 5 seconds or so. I cant really think of anything else I can do, but it seems like a time clock problem. Can someone please advise??? |
Re: 003 rack+ sync indicators flashing
I dunno from mac, however.
disconnect the octopre... does everything work nicely then? When connecting the octo, make sure your ins/outs are correct with your ADAT cable. When you change the setting on the octopre, does it make a difference to the flashing synnch lights? For me, I start the Octo first, then the 003, set the clock to ADAT and off I go.. Whenever I do not turn the octo on, PT will revert to internal clock.., so when I do want to use the octo I have to be sure and reset PT first or it will not work.. This is all basic stuff and I'm sure you've checked it, but go through it again and reset your clock. Best of luck.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Thanks for the advise, but yeah unfortunately I had covered all of that. The octopre doesn't seem to have anything to do with the problem, even stand alone the sync indicators keep flashing.
I can record, and pro tools works ok, except the glitch. But the problem means its not running correctly and I cant use my octopre. |
I'm having the same issue. Just bought a 003+ and cannot get my sync lights to stop flashing. Word Clock is set to internal and I'm not running anything else with it. Suggestions?
003+ will not sync. All sync lights are flashing?? | timothyARLO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-18-2011 04:55 PM |
003 Rack hardware issues - flashing and clicking | jiagap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-22-2009 10:44 AM |
click noise and flashing LED on Digi 002 rack | saw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-08-2003 12:19 AM |
Digi 002 rack clicking noise and LED's flashing inside | saw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-07-2003 06:15 AM |
clip indicators | Guruman | Tips & Tricks | 2 | 04-16-2002 12:56 AM |
