Old 10-06-2010, 02:01 PM
zedhed's Avatar
zedhed zedhed is offline
Default Flyin Blind
I have been using my 11R with no problems for over 6 months now and suddenly I have somehing wierd goin on.
When I plug my guitar into 11R, do the usual create 1 mono 1 stereo track assign mono to guitar in and stereo to 11R I can hear my guitar coming through the monitors, but with no 'effects'. (Tried scrolling through patches)
If I record onto both channels I cannot hear effects while recording, yet when I playback the recorded channels all effects have been printed to the stereo track just as they should be.
I first noticed this problem when I re-amped the mono channel. So, I create a send (Re-amp L/R) on mono channel to stereo channel with 11R input selected . In control window Rig input selected to Re-amp L/R.
The frustrating thing is that I can't preview my sound so I'm printing to a track 'flying blind' which is not good especially when using the wah.
I'm wondering if I have inadvertantly done something in pro tools that is stopping me from hearing the effects as I'm playing. (no mute/solo buttons are on at the time).
As I said, I have had no problems for so long that I'm totally confused as to why this would suddenly happen.
I'm running 11R firmware 1.03 (reinstalled) & PT 1.04 (reinstalled)
Is there any software updates that need to be installed with firmware ver 1.03?
Any help would be much appreciated.
Old 10-06-2010, 03:14 PM
zedhed's Avatar
Default Re: Flyin Blind
Just found this in the FAQ section;
In the "Track" menu, "Auto Input Monitoring" should be listed (this is the default monitoring setting for Pro Tools LE). If the "Track" menu instead shows "Input Only Monitoring", click on it to change the monitoring mode to "Auto Input Monitoring".
I'll give this a try when I get to my 11 R next
Old 10-06-2010, 03:58 PM
Sean Halley Sean Halley is offline
Go to IO Setup and delete all of your input assignments, and then hit the Default button. It sounds like some assignments got swapped, and you're hearing the direct when you want to be hearing the Rig.
S..
"it's not about making the changes, it's about playing ideas in time"
Scofield...
Old 10-07-2010, 03:59 PM
zedhed's Avatar
Ok I'll give that a try. Thanks for the suggestion Sean, Much appreciated.
Old 10-11-2010, 03:08 AM
zedhed's Avatar
Thanks Sean...It worked
I use a Mbox micro to be able to work while mobile. Switching and saving with micro must have stuffed that up me thinks!
Blind leading the blind - How to export single audio tracks? Leee14 Pro Tools 10 13 10-10-2012 04:10 PM
Am I blind? ejwells 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-10-2005 04:29 PM
Blind users Andy WAardle General Discussion 1 03-10-2005 05:47 PM
ADC blind test ... john1192 Pro Tools TDM Systems (Mac) 19 05-30-2004 06:39 PM
Macs for the blind. editor General Discussion 0 07-11-2000 03:56 PM
