Command 8 dead fader already?!!
Hi there.
This command 8 is not used since we opened the box for more than a couple of hours and I already have a dead fader. To be precise, fader#2 stopped responding yesterday evening. It won't communicate with pro tools at all. When I did a group fader test, only once would it move together with the rest. However, when I used this fader for the group test, all the other faders followed. Do you think that it is a firmware problem that could be solved with a simple update? I hope it isn't anything more because I'm based in the mainland of Greece, and even in athens, digi support is not the best available. |
Re: Command 8 dead fader already?!!
You should try installing the latest firmware and see if that helps at all.
Hi Digi and many thanks for getting back to me.
The problem seems to go away when I turn the unit off and then back on. But after a not very long session, fader no.2 stops moving again. And this happened three more times. Any suggestions? |
Contact Digidesign Technical Support by phone for further troubleshooting - you may have a defective fader...
650.731.6100 |
I had a similar problem last year. I ended up sending the unit back to Digi and had the main board replaced. Just in time as my 1 year hardware support was allmost up. Works great now, no trouble.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
D-Command ES + Fader Madule Fader Problems | FedericoF | ICON & C|24 | 11 | 05-24-2013 04:27 PM |
C|24 dead fader | WildHoney | Pro Tools TDM Systems (Mac) | 5 | 02-24-2011 05:19 AM |
Dead Fader. | Drew Mazurek | ProControl, Control|24, Command|8 | 1 | 10-29-2005 02:32 PM |
Dead Fader | Prelude Studios | ProControl, Control|24, Command|8 | 3 | 02-03-2005 09:52 AM |
Dead Fader on Fader Pack | engineerjoel | ProControl, Control|24, Command|8 | 4 | 08-28-2003 11:05 AM |
