Quick Mute Headphones Feature?
I love how you can tap the speaker button on the interface to turn it red, and mute the speakers. I wish you could do this with the headphones in some way, maybe a knob press, long press or a double press on the headphone button.
When you are recording yourself or artists. And you want to playback on the monitors. It's a pain to have to go and then manually use the knob to turn down the volume on the headphones. It would be much easier to just press the headphone button in some way to mute them. You could quickly mute back-and-forth between speakers and headphones. For playback after tracking. |
Re: Quick Mute Headphones Feature?
I do not know of any monitor controller that has either/or switch for speakers and headphones. Everything has mute button for both though. It takes a second to click both, so I have never seen that a problem.
If that is essential to you, there is a solution you can do yourself. First of all you need to route speaker monitoring and headphone monitoring to separate outputs, say 1-2 and 3-4, then have a box that accepts both and only outputs one pair. Toggle the switch, done. Google "passive monitor switching box" and pick your poison. Though most of them also have middle position where both outputs are active. Best ones are expensive because they are really well made, probably even handmade. Or, if you really want to do it in software, here's a trick. Solo safe everything and then create two distinct monitoring auxes (1-2 and 3-4 outputs) with obviously sharing same input. Then set your soloing to X-OR. That way whichever monitoring aux you are soloing will automatically mute the other one. But it also requires that speakers and headphones have different outputs.
Another option; feed your headphones via sends on your tracks and add a MASTER track assigned to the headphone outputs. Use that master to quickly mute or turn down. Having said that, I have never needed to do what you describe
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
I suppose it would nice but since I am going to take off my HP's anyway when I want to listen to monitors. Simply taking them off and I do not turn them down which works for me.
Is the idea that what ever little sound might be heard from the HP would interfere with monitors sound ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
I appreciate the response is here, but I really think they are overcomplicating the situation.
You can quickly tap to mute the speakers. They should make it so you can quickly tap to mute the headphones. This seems simple, logical, and intuitive to me. |
And it's far from overcomplicating.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I've had my Carbon for a year now and never even thought about until someone brought it up in a thread here.
And honestly don't remember if my Omni (for 8 years prior ) had such a feature ?
https://www.sweetwater.com/store/det...-headphone-amp Focusrite makes a far cheaper, but great one also. Like in the $400 range. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Quick keys or Shortcut for Mute? | Goldencd | macOS | 7 | 10-26-2020 04:33 AM |
how can i mute tracks in headphones but not my monitor speakers? | xstortionist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-11-2009 09:22 PM |
2 region mute problems (Feature request?) | Felix Rost | Pro Tools TDM Systems (Mac) | 2 | 05-01-2009 10:42 AM |
Mute Pref Needed Feature - PTLE 5.2 | stupetech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-09-2002 06:39 AM |
