Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 11-24-2021, 08:38 AM
PhilipKapadia's Avatar
PhilipKapadia PhilipKapadia is offline
Default Re: This license can only be activated to an iLok. Please plug one in."
Originally Posted by Bennett Paster View Post
You likely need an iLok account, even to use only the cloud authorization (not physical iLok). Have you set up an account and logged into the iLok License Manager app? Apologies if this seems obvious.
I have an Ilok account, thanks for the suggestion though! Sometimes the complex issues have a simple solution :)
[email protected]
https://philipkapadia.com/stuff
Media Composer & Nexis Shared Storage ACSR
JFreak's Avatar
JFreak JFreak is online now
Sorry, I meant iLok support. Avid provides trial license to your iLok account and if there is a problem activating the license, it is iLok problem, not Avid problem.
Janne
Old 11-24-2021, 08:40 AM
its2loud its2loud is offline
I’ve had cloud issues with trials as well even though Avid says it will work.
One thing to check is to make sure you have the latest version of iLok installed. Sometimes having an outdated version will cause issues.
Also, I saw that you have a ProTools First license. That definitely won’t work in the cloud and it’s possible it’s getting confused with that license. I’ve had that happen as well.
Old 11-24-2021, 09:17 AM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by PhilipKapadia View Post
...Here is a screen recording of the error: https://streamable.com/wvzfvi...
Your recording mostly shows your drive (DESKTOP) with your Pro Tools First license. That's separate from the Pro Tools trial. Your iLok Cloud (just above that) shows 0 licenses though our system here shows the trial license activated this morning. The error at 0:28 states that you can't manually activate a license to your iLok Cloud in Automatic mode. Try switching to Managed mode for it to act like an iLok USB key.
So... is this working now?
linkedin
Old 11-24-2021, 02:33 PM
I always forget about managed mode. Ah the little things.
  #16
Old 11-25-2021, 10:27 AM
Just an update, Have contacted Avid support to try to fix this. Will update here once fixed!
[email protected]
  #17
Old 11-26-2021, 12:36 PM
Wondering if anyone might have any other ideas?
[email protected]
  #18
Old 11-27-2021, 07:59 AM
Buy an iLok or try authorizing on a different computer to see if the cloud authorization works.
Did you try any of things that were suggested?
Pro Tools License Cant Be Activated on iLok Dullabills Licensing & Accounts 3 02-11-2020 11:33 AM
Application Manager shows activated Pro Tools licence as "Not Activated" ForrestW Licensing & Accounts 27 09-28-2017 07:27 PM
Activated plug-in rental not depositing license in ilok Heretiger Licensing & Accounts 2 04-12-2017 02:34 PM
"Factory Promo UB" - "Eventide" - iLok license - What plug-in is this? Intini Pro Tools TDM Systems (Mac) 7 08-31-2012 08:27 PM
