Old 11-16-2021, 09:42 PM
GregX GregX is offline
Default Bounce Mix offline makes longer bounce than 'online'
Hi, I've never seen this before: the 'offline bounce' is 3:32 minutes long, with almost a minute of silence at the end, but the online bounce, where you hear the song as it bounces, produces a correct 2:24 minutes long song, with no extra silence at the end. It uses the same selection region for both cases. There is no audio or automation after 2:32.
Nothing I do makes the offline bounce different than 3:32, even selecting four minutes, or two minutes, it always comes out as 3:32.
I've restarted Pro Tools, (ver 21.10.0 Windows), but that had no effect. Is there some setting or something I don't know about? Thanks.
Old 11-17-2021, 06:33 AM
its2loud its2loud is offline
Default Re: Bounce Mix offline makes longer bounce than 'online'
How are you selecting the time of the bounce?
Do you have Link Timeline and Edit selection turned on?
If not, are you selecting the length of the bounce in the timeine or in the edit window?
Old 11-17-2021, 12:42 PM
Hi its2loud, I was selecting the area to bounce from the edit window, but had Link Timeline and Edit deselected. Now that I have selected it, everything works fine. I've experimented with the different selection methods you suggested, and I understand it much better now.
Thanks you so much for taking the time to help me out!
Greg
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 andresix Pro Tools 13 11-19-2021 07:03 PM
Bug of the week: HDX offline bounce different from online bounce XJENSEN Pro Tools 2020 25 02-24-2021 10:17 PM
Bounce to disk offline error on 2018.4! take care, use online instead! tamtamstudio Pro Tools 2018 25 08-19-2018 02:36 PM
PT 12 offline vs online bounce AntonFAudioDesign Pro Tools 12 12 04-05-2015 04:51 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
