Old 07-26-2021, 05:53 PM
soundartsonline soundartsonline is offline
Default Which plugins eat up the most resources?
Reverb, Eq, Delay?
What is the most conservative way to approach using plugins so you don't run out of resources?
Looking forward to your replies!
Old 07-27-2021, 01:43 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Which plugins eat up the most resources?
It depends on the actual plugin, not the type of plugin. I have limiters eating all my resources and limiters hardly using any. It's pretty much trial and error. Plugins needing more resources are generally reverbs, upmixers, AI powered tools, denoisers, etc. Plugins like dynamics, EQ, delay, generally take less resources. But again, all type of plugins come in all shape and sizes so it's really dependent on the plugin itself, not what type it is.
Old 07-27-2021, 07:42 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by soundartsonline View Post
...What is the most conservative way to approach using plugins so you don't run out of resources?...
Most of the stock AVID plugs are easy on the CPU.
Click for audio/video demo
Click for resume
Old 07-27-2021, 10:25 AM
That is good to remember. Plus, many stock plugins will run with zero added latency(learning which can help you keep latency down for tracking, while still having good sound, which is especially helpful for headphone mixes).
Here are some plugins that are serious cpu hogs:
1-every amp simulation plugin
2-Izotope Ozone(a great plugin but forget about using it while tracking)
3-Melodyne(I tend to commit Melodyne edits as soon as I finish a track)
4-some convolution reverbs(but SPACE doesn't seem bad)
Old 07-27-2021, 11:29 AM
Southsidemusic's Avatar
No plugin will run at ”zero” latency as thats an impossibility but ”some” of the boring stock plugins have a low latency.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-27-2021, 12:09 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by Southsidemusic View Post
... boring stock plugins ...
stock plugs that I (sometimes) use:
trim
1 or 7-band eq
Pultec EQP1A (is that one stock?)
blk1176
gate
Dverb
delay
audiosuite gain, pitch, reverse, normalize
Xpand
Click for resume
Old 07-28-2021, 06:26 PM
Sorry, but I believe you are mistaken. To prove it, I put up a track of music with no plugins. I duplicated the track and added a stock plugin that reports 0 latency and turned Delay Compensation off. No phasing of any kind. I then reversed polarity on the plugin and the pair of tracks null 100%. That tells me that the plugin in question(EQ3-7 band) does indeed run with zero latency. Back in the LE8 days, I also often used BF76 on a drum bus(fed by sends on the drum tracks). That plugin also reported zero samples of latency(and still does) and again, it never caused any phasing. I'm not offended if you can prove me wrong, but my evidence tells me that my assessment stands
Old 07-28-2021, 09:24 PM
Sardi Sardi is online now
Yep.
Loads of plugins induce zero latency to the signal path.
Running out of Juice - Native Plugins hogging resources ? [email protected] Windows 8 05-17-2012 08:37 PM
Out of CPU Resources erant1 Pro Tools TDM Systems (Mac) 0 06-03-2007 05:10 AM
CPU Resources Dallas002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-08-2006 08:43 AM
Help! DSP resources not enough! chanlon25 Pro Tools TDM Systems (Win) 3 07-12-2005 09:03 AM
web resources badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-13-2002 09:33 AM
