High Memory Usage - PT 2021.3
Hi, I've noticed that if I open some sessions the memory usage goes up to 30%. But if I manually deactivate the plugins the memory remains fixed at 30%.
If I close the session, Memory usage is still 30%. If I reboot protools Memory goes back to minimum percentages. I think this could affect memory load on other sessions. It doesn't free up memory. |
Re: High Memory Usage - PT 2021.3
I've never noticed this thing in my previous system |
Like I said this isn't strictly a PT problem. What else do you have running when working in PT? |
Is this what mac Activity Monitor reports? If not, check there also.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
My system was using 14.4 GiB of ram w/out PT open. Opened PT and it went to 15.78Gib holding steady. Opened one of the largest sessions I have, and it went to 17.4 GiB. Make sure you don't have anything else opened, i.e. browsers, Apple Music/iTunes... etc... Especially FireFox... that's a memory hog!
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
I'm seeing 5.63 gig with just MacMail and Firefox open. As measured in OSX Activity Monitor. With PT open and a 25+ minute 42 track session open the memory load is 15 gig. |
No it’s the memory usage display of PT
Mac Pro 2019 - Monterey - Macbook Air M1 - Apollo 8p (x2) - Apollo Twin X - Ferrofish 16Mx - Avid S1 Multi-unit |
It’s not my case cause if I close and reboot Protools without changing anything else in the system...memory goes back to minimum levels. I think its a fight with some Acustica Audio Plugin. If I deactivate one memory goes down. My problem is that after closing the session PT still shows high memory usage based on that Acustica Audio plugin. It doesn’t release the ram.
Mac Pro - High Memory Usage (no session loaded) in Protools 2020 | Paulienat | Pro Tools 2020 | 5 | 12-22-2020 11:39 AM |
Memory usage too high on Windows | daeron80 | Pro Tools 2020 | 8 | 07-14-2020 07:26 AM |
Memory usage very high in empty session | Downtown_BE | Pro Tools 2019 | 5 | 12-29-2019 07:32 PM |
high CPU usage on PT8, something is not right | mr razor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 04-02-2009 09:57 AM |
CPU USAGE REALLY HIGH | METAFOR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-05-2004 01:55 AM |
