Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 07-14-2014, 09:50 PM
cjansson77 cjansson77 is offline
Default Native Instruments Plugins Not Listed in Inserts
Hi there, I'm hoping someone can help me figure out how to get my plugin's back. Ever since I upgraded to PT11 (used to have 9), my NI plugins disappeared from my inserts menu. Here's my setup:
I'm using a fairly new Macbook Pro running OS X Mavericks, w/ a 2.8 GHz Intel Core. I have Pro Tools 11 installed, and I use an M-Audio Fast Track Pro as my interface. Also, I am connected to a Mercury Elite-AL Pro external drive with a FW800 cable.
Like I said, I used to have access to my NI plugins (specifically Maschine and Guitar Rig 5), but after I updated to PT11, they disappeared from my inserts. The same thing happened with Melodyne, but all I had to do was reinstall that, problem solved. However, a simple reinstall didn't work for either Maschine or Guitar Rig 5. What's the next step? Thanks in advance.
Old 07-14-2014, 09:54 PM
Default Re: Native Instruments Plugins Not Listed in Inserts
You need to read release and install documentation.
Pro Tools 11 does not support RTAS or AAX-32 plugins, only AAX-64. You need to upgrade all third party plugins to AAX-64 to use with Pro Tools 11. You have to check whatever plugin version you are installing is specifically AAX-64 (and also compatible with your OS version etc.).
Native Instruments Plugins / PT 10 Issue everlast88az Pro Tools 10 0 11-19-2012 01:52 PM
How are native instruments plugins on PT8. chazc080488 Virtual Instruments 15 08-21-2010 10:50 AM
PT 7.3 with Native Instruments plugins HELP!!!! kindsounds Pro Tools TDM Systems (Mac) 0 07-03-2008 06:23 AM
Native Instruments PTDM PlugIns trouble at 7.1 Tonabteilung Pro Tools TDM Systems (Mac) 3 05-19-2006 02:32 PM
native instruments plugins adam_w1 Tips & Tricks 5 04-19-2002 05:47 PM
