MASTERING TIPS!!!!
can anyone give me some mastering tips? i have a digi002 with a g5 and i only have the basic pro tools compressor....
i am mixing rock and hiphop |
Re: MASTERING TIPS!!!!
If you expect to create competitive commercial works, you will now have to invest in the software to do this. For audio processing, you will need, at minimum, the Waves Platinum bundle which includes the standard in the industry L2 limiter and the new L3. Also inlcuded are the Linear phase EQ and multiband compressor. Not only do these plugins provide you with great processing power, they also give you a user interface that is lacking in the Digi Audiosuite bundle. You can try the Waves software for 14 days free to get a feel for it. You will also want to look into your sequencers for competitive synth effects. Remember, Digi makes its money on hardware, but you do not get a pro-studio for a mere $2K. Although Digi's plugins are good,even better than many of the free LE bundles included, they are by no means enough to obtain professional results. |
HI woodbeatz,
donīt give TOO much for that post above. I agree that the digirack plugs are quite insufficient, the Comp is awfull and the EQs unpredictable. I use them only to switch phase these days. But you DON`T NEED Waves Platinum!!!!! There are cheaper and better alternatives. www.elementalaudio.com has professional Compressors and Linear Phase EQ for $250 in THE BUNDLE!!! and the Sony Oxford Inflator is just under $300 and way better than L2. and the Sony Oxford bundle is just $660 at www.sweetwater.com and the great RTAS Bundle from www.prosoniq.net is only some $200 includes the Dynasone Multiband Comp. If you like to stick to Waves than rather go for the Mastering Bundle, obviously. But I have to say, I dislike Wavesī elitist behaviour more each day, and there are lotīs of other plugs around that are cheaper, better and less cpu hungry. I strongly advice you to read ALL of their customer policy. so far MY OPINION on mastering tools. for good info about how itīs done check this link: http://www.theprojectstudiohandbook.com/directory.htm If you can afford it let the mastering be done by a professional audio engineer but INSIST to let you watch him. You could learn more in a one hour session than in months of reading. regs PS: I just saw that URS has extended their $50 offer on the BLT EQ. THIS you should be trying for sure. Itīs not mastering but comes in handy and easy to sweeten up your sound! www.ursplugins.com
last: PT11.3.1 |
I like T-Racks.
I am very interested in this as well. I compression usually all you need for home studio mastering? If so what compressors would suggest (both plug-in as well as rack, please)? Would it be safe to say you could create a master fader and run a compressor/limiter on that alone? Would you also want to compress individual tracks, such as drums and bass? What do you think of T-Racks?
basically "mastering" is called the work on the FINAL sterao tracks. Everything before is mixing. I strongly suggest to check "the project studio" link above and/or get some book from Bob Katz for more info. IMHO T-Racks is unfit to do even semi-pro mastering. Personally I donīt like the sound of it at all (too muddy, too much the wrong color for my needs and taste) basically you need for mastering a linear phase EQ, an excellent reverb, a loudness tool and eventually a comp. If you canīt afford $$$$ for hardware then rather stick to the plugs! But you canīt get wrong with a RNC for $300. Great Tool! Compression is a delicate topic and the best compression is the one NOT USED. You always need to know why and how you want to apply compression. You can do sounddesign with it, or use it to get more punch or... As a general hint: do not change settings while playing. stop - adjust parameter - hit play... When you do it during play, your ears are more likely to adapt to it as a kind of effect and you canīt destinguish the changes. Besides you can find your desired settings faster when you adept that skill. See it like the typewriting skill. You are much faster and more accurate if you donīt watch your fingers. And as Joe Meek inventor said "if it sounds right, it is." If you donīt know what you want you donīt know how to achieve it. Listen to CDs you like and try to imitate and go from there. This all reflects just my personal learnings and is neither complete nor the last words youīll ever hear. so far regs
last: PT11.3.1 |
Somewhat off-subject but still relevant - multi-band compression is BY FAR - NOT standard issue in most professional mastering rooms. Most will have one available - but use it only when needed. Thinking that a multi-band compressor is a must for EVERY song you master is a falicy propogated by Waves and the like to sell you more crap. If you were to poll the top mastering folks - you would find most use general limiting and perhaps frequency-dependent compression as needed, and go to full multi-band compression only as either a last resort or use it VERY VERY lightly. For the most part - I find if you NEED multi-band compression - what you REALLY need is a proper re-mix.
Multi-band limiters can be VERY deceptive to the ear - especially in a less than ideal monitoring environment. In un-experienced hands - you can make your mixes sound very very boring & lifeless, very very fast. Can you make them loud as all He**? Of course - but that's really NOT the point of proper mastering, which when it comes to overall level - should make your mixes as loud as they CAN be, without sacrificing the listening experience - NOT as loud electrically possible. In today's world - you CAN achieve pretty nice results "in the box" without the benefit of good analog mastering - but most PT mastering sounds OK to relatively horrid due in part to what I've discussed above. Dump the multi-band comp, focus on what serves both the song and the album and keep in mind that if you have a decent mix - less is almost ALWAYS more when in comes to mastering. After all - EVERY stereo I've ever owned has had a volume knob! --S
Stephen Marsh Mastering 1617 Cosmo St Loft 106 Hollywood, CA 90028 310.598.6038 tel 5685 fax http://www.StephenMarshMastering.com |
Sorry guy, the only way to do it right is to take it to a mastering engineer. I can get some slamin mixes with my rig but in no way belive its done till I send it off to be mastered. I am a firm beleiver that who ever mixed a project should not master it. If you are serious about your project, pay and have it mastered. My $.02
"adults are obsolete children" Digi02/mbox.shuttle an35s,AMD 3200+, 2x512mb geil pc3200, maxtor 60,120 Gigs, Ati Rad7000 dual svga. |
Mastering tips | timcrow420 | Pro Tools SE and Essential (Win) | 2 | 05-17-2012 05:32 PM |
Using the L2 And C4 For Mastering.. tips | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-14-2004 07:04 PM |
Mastering Tips | Kleekoh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 07-28-2003 04:47 PM |
Tips on Mastering Hip-hop | Hardnox | Tips & Tricks | 18 | 07-27-2003 11:39 PM |
tips for mastering | Alberto Tarin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 03-08-2000 08:09 PM |
