PT Crash when using Time Compression/Expansion
All of a sudden....when using Time Compression/Expansion audiosuite plugins (Avid TCE, Serato PnT Pro, Waves SoundShfit, etc) i managed to run teh analize teh audio...but when i clic "render" Pro Tools immediatlçy crashes.. Any suggestions/solutions ? THank you in advance |
Re: PT Crash when using Time Compression/Expansion
Suggestion #1 is to tell us complete, accurate details about your system. See “help us help you” at the top of the page.
Avid HD 12.5
Digidesign Avid Digiconsole 003 Windows 10 Serato PnT Pro 3.01 Avid system Time Compression/Expansion i select the audio track....i open under audiosuite either referred plugins...clic analize....up until taht everything seesm to go well....i listen to preview within the choosed plugin and everything sounds correct adn fine....as soon as i clic RENDER Pro tools immediatly crashes |
You’ve posted to the wrong forum. This one is for the current version. You want the legacy forum for 12.5
And you didn’t really read “help us help you,” either. That’s not enough info to even make an educated guess. You still have provided zero info about your computer.
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz 3.80 GHz
32Gb ram NVIDIA GeForce GT 610 Mobo Gigabyte GA-X79-UD3 |
Oh, fer crying out loud!!!
Ever hear the term “you have to participate in your own rescue.” ? https://duc.avid.com/showthread.php?t=300050 |
Well....sadly or peehaps luckly i'm not used to have to ask for help so it would properly be better to forgive my lack of knowledge ...
Click on the link and follow the instructions.
Le Mec
You are going to need to make a start on standard troubleshooting yourself, and should really be doing that before posting here. Make sure you follow the instructions for your OS and Pro Tools version. Things like trashing prefs should just be second nature and done any time you find a problem. Use Pete Gates free PT Prefs utility to make it easier for yourself: http://petegates.com/pg-pt-prefs.html Problems related to plugins are often....ta da surprisingly... due to the plugin or incompatibilities of the plugin and the version of Pro Tools you are running. So you need to check if you have the correct compatible plugin versions for the version for Pro Tools and the operating system version. Lots of information in Avid knowledge base articles you can Google for. And when running on Windows and asking for help here it's expected that you provide a Sandra report. It might not help too much in this case, but it's handy to just get that out of the way. All described in the stuff you need to read. |
Time Compression/Expansion | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 03-05-2006 05:46 PM |
Time Compression Expansion | Wicked-Mama | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-05-2003 05:25 AM |
TIME COMPRESSION EXPANSION | vdosc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-21-2003 03:25 PM |
time compression/ expansion | wendyF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-15-2003 09:03 AM |
time compression/expansion | oscargoldman | Tips & Tricks | 2 | 05-03-2000 07:20 AM |
