Old 03-06-2001, 01:01 AM
otto otto is offline
Default selecting drum bank in N5ex take 2!!
I've tried doc22's suggestion - which did enable me to select the drum bank through protools (thanks)
But when I record, it seems to revert back to the sound from a different bank. I think, for some reason it's recording channel 1 instead of the selected channel 10.....
......help!
http://www.ottomedia.com.au
Old 03-06-2001, 06:17 AM
doc22 doc22 is offline
Default Re: selecting drum bank in N5ex take 2!!
otto,
Are you trying to use the Korg in "Program" mode? If you are, try switching it to Multi or whatever they call the multitimbral mode. Also, you may have to turn off "local control". Read my new response to your previous post.
Hope this helps.
doc22
Old 03-06-2001, 03:07 PM
yeah thanks doc22,
i did have it in multi with local off - but maybe after all my playing around, something else needs to be reset. I might try to reset everything to default & see what happens.
Old 03-07-2001, 02:23 PM
doc22,
I tried your suggested bank numbers etc in a completely new project & it all worked fine - must have been something with that project or midi track
thanx for your help
Bank D on SC48? Future Custom Bank perhaps? digidesigner VENUE Live Sound Systems 1 01-11-2010 07:20 AM
Korg N5ex Ryan Young MIDI 0 10-28-2004 11:00 PM
Selecting the different drum banks from Quicktime Instruments for use in PT (how?) EricWillhelm MIDI 0 06-07-2003 12:04 AM
Anyone using Filter bank-Compressor bank c.evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-13-2001 10:16 PM
selecting korg N5ex drumbank from within protools otto MIDI 4 03-06-2001 06:04 AM
