Old 03-05-2001, 04:06 AM
otto otto is offline
Default selecting korg N5ex drumbank from within protools
i'm a midi newbie - can't work out how to select drum bank on the N5ex, as it doesn't have a bank number like the rest of them. I've selected channel 10 and have the N5 selected as the input device (the N5ex wasn't listed), but can't get to the drums.
anyone???
http://www.ottomedia.com.au
Old 03-05-2001, 06:18 AM
doc22 doc22 is offline
Default Re: selecting korg N5ex drumbank from within protools
otto,
If the N5ex is like the N5DR then the drums are probably located at CC#0=62 and CC#32= any number. Program numbers are then 0, 16, 25, 32, 40, 64, 24, and 48.
Let me know if this works. I'll be adding these to the Library soon.
doc22
Old 03-05-2001, 02:35 PM
thanks - i'll try it tonight
Old 03-06-2001, 01:03 AM
by program numbers do you mean patch numbers??
i'm gradually catching up with all the midi jargon
Old 03-06-2001, 06:04 AM
otto,
Yes, that would be patch numbers. Korg uses the word Program, so that's what I used. I took a look at the N5 in a list of synths that I have (I don't have an N5). It appears that you have drum kits at:
CC#0 CC#32 Patch
62 0-- 16,24,25,32,40,48,64
127 0-- same
61 0-- 0,8,16,24,25,32,40,48,49,50,56,127
126 0-- 0,1
See if these work,
doc22
[This message has been edited by doc22 (edited March 06, 2001).]
Protools freezes when selecting Digi 002 in playback engine Jesseb651 macOS 5 07-17-2012 03:56 PM
ProTools User Wishlist / Shortcut for Selecting attached regions? Arya44 Tips & Tricks 2 09-20-2009 06:48 AM
HELP - Protools LE 7.3 crashes when selecting MBOX 2 Output revola 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-17-2008 09:16 PM
Korg N5ex Ryan Young MIDI 0 10-28-2004 11:00 PM
selecting drum bank in N5ex take 2!! otto MIDI 3 03-07-2001 02:23 PM
