SC48 User Partition Error
"User partition could not be found. Recommends System Restore" What would cause this? The console then boots up completely blank.
Hey Sheldon or service, need your help please on this one. Were in the middle of a show as we were able to load an ok how file from our jumpdrive after the console came up with a clear file. What causes this message and is the stability of this issue gonna get us through the next 4 hours?
Chris Hunt McKinney, TX SC-48 3.0/ ProTools 10 / Mac Book Pro 13" i7 / Limelightband.com
Re: SC48 User Partition Error
Hi guys,
The "user Partition" relates to the hard drive, but it's difficult to say exactly what the issue could be without further diagnostics. If you're up and running and the hard drive were to fail the console will kick into its backup mode, allowing you to continue to mix in a scaled back way - faders and mutes. For urgent matters (like this!) feel free to call the support line at 650-731-6111. Sheldon |
Hey Sheldon,
Ok, I got it home and started it back up. This time, it gave me several error messages telling me that critical components could not be started and asked me to try again or continue. After several attempts at each option it gave me, it never did start up at all. I re-installed to factory settings and now everything works perfect. I am very confused as to what would have caused this harddrive error to the extent of not being able to startup at all, but now after re-installing everything, all is fine. Does this sound like the typical hardware problem? System test shows all tests passed with no failures after console restore. Should I be concerned that this happen again? Could is be a faulty HD? Thanks!
Any help on this would be much appreciated. What would cause the console to boot up, give me a user partition error, startup with a clear console without any user saved anything, accept an old showfile and work fine. Then the very next day, when booting up, gave several error messages saying that critical components could not be found and would not boot up at all. A system restore worked perfectly and now I'm up and running just fine. Anyone had this happen? Thx.
Win7 Multi User or Partition to run 2 DAWS? | UMFM | Windows | 5 | 02-04-2014 09:58 AM |
New SC48 User - Tips on configuration | justinphilip | VENUE Live Sound Systems | 1 | 10-29-2013 06:14 PM |
partition my drive or create a separate user for pro tools? | wreckthisplace | General Discussion | 11 | 06-23-2007 03:12 PM |
weird error when loading 6.9.2 after partition | wreckthisplace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-03-2006 02:14 PM |
Keeping the Same User folder for LE & HD Partition | mwingerski | Pro Tools TDM Systems (Mac) | 2 | 08-18-2005 01:23 AM |
