Old 01-04-2011, 11:29 AM
bluemix bluemix is offline
Default SSL Alpha Link Madi AX and xtreme64 card
Avid apparently refuses to offer support for PT9. Awesome.
My firmware is up to date as are my drivers. SSL has assured me the issue is with PT9. I can't get a buffer setting below 64 or above 1024 regardless of sample rate. Everything else is working fine. What is going on? Have I set something up incorrectly or is Avid purposefully crippling 3rd party devices?
Please help. I cross graded from PT LE8 in November and would really like to get this setup working optimally.
Thanks.
Old 01-04-2011, 03:12 PM
CME CME is offline
Default Re: SSL Alpha Link Madi AX and xtreme64 card
Thanks.
FWIW that seems very normal to me. The buffer settings are dependent on the hardware attached. So far I've not heard of many 3rd party interfaces working at a buffer lower than 64 samples with pt9. It may have to do with the software, but it's like that for most 3rd party devices.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 01-04-2011, 05:13 PM
Thanks for the response.
I'm actually worried less about the 64 buffer setting than I am the 1024. Why would PT9 limit an increased buffer setting? I was able to get 2048 with my 002...
Old 01-04-2011, 06:22 PM
Goldencd Goldencd is offline
Dumb question.. But why would you want higher than 1024?
Old 01-04-2011, 06:23 PM
That setup at 256 will run laps around your LE setup at a 508983993884 buffer
Pro Tools 10 and SSL X Logic Alpha Link Madi AX Basslab macOS 0 01-25-2013 09:07 AM
HDX Madi with SSL Alpha-Link AX sammyfarr Pro Tools HDX & HD Native Systems (Mac) 3 08-11-2012 04:11 PM
PT 10 + SSL Alpha-Link Madi-AX and MIDI bfire Pro Tools 10 1 01-14-2012 04:42 PM
does Alpha-link Madi works with PT9? coloquinte Pro Tools 9 21 07-11-2011 11:09 PM
HD PCIe with SSL Delta link MADI HD Alpha link MADI AX Juraj Bernáth Pro Tools TDM Systems (Mac) 3 09-10-2009 07:13 AM
