Old 12-02-2009, 02:28 PM
Lukehanigan Lukehanigan is offline
Default How do I link Edit Window & Midi Editor?
Does anyone know if it is possible to link the Edit Window with the Midi Editor? In particular I would like to be able to expand the Edit Window and Midi Editor simultaneously. Currently I have to expand one and then the other. It's getting a little tedious...
Old 12-02-2009, 03:12 PM
gdugan gdugan is offline
Default Re: How do I link Edit Window & Midi Editor?
I'm pretty sure you can't link the two windows. However, from the Edit window, you could use "Zoom Toggle" to view your MIDI/Instrument Tracks in "Notes" view. If you set it up correctly, when you select a track and press zoom toggle, the track will become huge and will display all MIDI notes. As you horizontally zoom in the Edit window, the selected track will zoom as well.
Old 12-02-2009, 05:40 PM
Thanks gdugan, I'll give it a try. Could be a temporary fix.
Opening MIDI editor at current Edit window position tooold macOS 0 01-08-2014 09:40 AM
Midi Editor window bobbyrichards Pro Tools 10 1 03-07-2013 02:29 PM
How to: Switch between sub-windows: Midi editor inside of edit window bashville macOS 3 10-20-2012 07:59 PM
Link Midi and Edit window Zoom? earthcorp Tips & Tricks 1 02-07-2010 05:48 PM
C8 Follows Link Track Selection in Edit/Mix window FluffyPost ProControl, Control|24, Command|8 2 01-20-2009 08:44 PM
