Old 09-23-2007, 05:28 AM
2fly 2fly is offline
Default Hidden tracks on CDs anyone know how it\'s done.
I get asked if I can hide a track at the beginning of a cd on a fairly regular basis and my stock answer is that they can do that at the mastering house.
However is it possible with Waveburner or Jam and if so, how.
Alan
http://www.2flystudios.com
G5 2.5ppc, 4gb ram, OSX 10.5.8, PT8.0.1cs4
Old 09-23-2007, 06:14 AM
southboundloco's Avatar
southboundloco southboundloco is offline
Default Re: Hidden tracks on CDs anyone know how it\'s done.
it can be done with cd architect
Pro Tools 11.2
Pro Tools 10.3.9
REAPER
MPTK2
ProFire 2626
Benchmark DAC1
Neumann KH 120 A
Avid Artist Mix
ASUS Sabertooth Z77, Intel i7-3770K CPU OC'[email protected], 32 Gigs RAM
Mac OS X 10.9.3 Mavericks
Old 09-23-2007, 07:40 AM
JFreak's Avatar
JFreak JFreak is offline
It is possible with Jam. The trick is to specify a longer pause between tracks and let the music play during the pause. Read the manual. Look for a keyword "offset".
Janne
Old 09-23-2007, 07:50 AM
Thanks. It's of to the manual for me.
Alan
Old 09-23-2007, 10:19 AM
Natural Sound Natural Sound is offline
No - you can't do it at the beginning of the CD.
It has to come after a track.
The beginning of a CD has to start with an ID#
Thomas Anthony
Natural Sound
Old 09-23-2007, 01:16 PM
Just found this on't web
3-36] How do I put "hidden tracks" and negative indices on audio CDs?
(2001/06/26)
With a little searching you can find an audio CD that will cause your CD
player to show a negative track time when one track finishes and the next
begins. The negative sections are usually filled with silence, but some
rare discs will have material in them. If you seek directly to the track,
you don't see (or hear) the negative-time section.
The trick here is also described in section (3-14). You can specify the
start position of an audio track anywhere within the track. The start
position is at time index 00:00 (in minutes and seconds, MM:SS), so the
music before the start point is usually displayed with negative time values.
When you seek directly to a track, the player jumps to time index 00:00, but
when you play through from a previous track you hear the entire track.
When using CDRWIN-style cue sheets, the actual start of the track is at
"index 00", and the place where the player seeks to is "index 01". The
distance between the indices is called the pre-gap. The Red Book standard
requires that index 01 in track 01 be at least two seconds (150 sectors)
from the start of the CD.
You can specify additional index markers, but most CD players will simply
ignore them. Some CD-ROM games have tried to use the index markers as a
form of copy protection, because they won't get copied automatically by
many programs.
If you want to create your own discs with "hidden tracks", you need a program
that gives you full control over where the index markers go (CDRWIN is one
such program). Combine two (or more) tracks with an audio editor into a
single file. Specify the file as a single track in the cue sheet, set
"index 00" to time zero, and set "index 01" to a point right after the
"hidden" song finishes. There are other ways to approach this, but this
is probably the most straightforward.
It should be mentioned that the only truly "hidden" track is in track 1.
Most CD players will play the entire disc, from index 01 on track 1,
straight through to the end, so any tracks you try to "hide" in the
middle of the disc are simply difficult to seek to. The only way to play
audio tucked into the pre-gap in track 1 on most players is to hold down
the rewind button.
Alan
Old 09-23-2007, 03:55 PM
oops - sorry, well then, there you go.
enjoy.
Thomas Anthony
Natural Sound
Old 09-24-2007, 04:11 PM
blackmacdaddy blackmacdaddy is offline
So you MUST use a PC to do hidden tracks? :-(
It's only R'n'R but I like it.
Old 09-25-2007, 12:04 AM
JFreak's Avatar
No. As I said, Jam does it nicely. I have done it for one mastering project and I definetely do *not* use PC's for anything.
Janne
Old 09-25-2007, 02:55 AM
pmklein pmklein is offline
The simple way is to take the last song, add about 30 seconds of silence (or whatever) to it and then add the hidden track you want to use and combine them into one file that becomes the last track. Then only the last song will have a track number and the "hidden" track will start to play after your 30 seconds of silence. Of course, on the CD label, you only list the runtime of the last song, not the addtional hidden track. You don't need any special software to do it this way.
Hidden tracks reappearing ??? Help please. Rich Pro Tools TDM Systems (Mac) 0 04-04-2011 10:46 PM
some tracks are hidden please help dj mastermind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-26-2007 02:27 PM
PT 7.3 Hidden Tracks ??????? jaaypeso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-13-2007 11:21 PM
Hidden Tracks Scoobster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-30-2003 09:44 PM
hidden tracks vtone Digidesign Hardware & Software 3 11-28-2000 02:25 PM
