Old 08-16-2007, 08:48 AM
pindebraende pindebraende is offline
Default Structure drag n drop
Hi there
I have tried to search for this, but couldnt find anything. So sorry
Anyone got the drag n drop function to work?
Im trying the best I can, but it just wont happen
Im on PT HD 7.1.
Thanks alot for helping out.
Regards
Mikkel
Best wishes,
Mikkel
Sonic Salute SFX Libraries
IMDB
Old 08-16-2007, 10:54 AM
jaaypeso jaaypeso is offline
Default Re: Structure drag n drop
I don't have an HD system so anything system related I can't be of too much help with, but I just know you have to drag the audio file or region into the left hand side of the structure screen called the patch list where the parts and patches are stored. If you try to drag and drop it in any other area it won't allow it. This is how I get it to work for me. Hope that helps even though i'm guessing you've tried dropping it everywhere on the structure screen already.
Old 08-16-2007, 12:31 PM
Thanks alot jaaypeso.
Yeah I pretty much tried to drag the sample any where possible. Still nothing happens.
Thanks again.
Mikkel
Best wishes,
Mikkel
IMDB
Old 08-16-2007, 07:52 PM
Mikkel, have you tried reinstalling Structure, not the Samples, just the Structure plug-in?
filosofem
Aaron Mulqueen - 001 HD Native
Old 08-17-2007, 03:45 AM
Thanks filosofem
That could very well be the problem. I´ll try that.
Thanks
Mikkel
Best wishes,
Mikkel
IMDB
Old 08-17-2007, 02:02 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Here is the Spot where I need to drop the regions. It brings up the window you see.
noise | jimlongo
Old 08-18-2007, 12:50 AM
P A M P A M is offline
Hi there
Im on PT HD 7.1.
Regards
Mikkel
You are running 7.1 - I would suspect it could have something to do with not running at least 7.3.1..
Cheers
PAM
Euro-Sound Studio
www.euro-sound.org
Old 08-18-2007, 04:33 AM
Thanks PAM
Yes I´ve been thinking of that too. I´guess I have to take plunge to 7.3 someday
Regards
Mikkel
Best wishes,
Mikkel
IMDB
Old 08-18-2007, 04:10 PM
Mikkel, so you're saying that reinstalling the Structure Plug-In didn't fix your drag and drop problem?
By the way, 7.3 isn't necessary to run Structure, however, if you were wanting to take advantage of Disk Prioritization for example, then 7.3 or higher is needed.
Drag and drop is such a core integrated function that it should work with any Pro Tools 7.x system.
Mikkel, could you give us your system details and how you've gone about performing this function and how you've tried to troubleshoot it ...maybe DigiTechSupt can chime in.
filosofem
Old 08-19-2007, 05:31 AM
Chri Chri is offline
I am on Pro Tools LE 7.1.1cs2 on a Mac Pro using Structure 1.0.5154.
For me the drag and drop feature also doesn't work.
When I drag a region over to the Structure Window, it behaves like is was not there at all and the Region gets dropped at the underlying edit window.
I am disappointed by that, because the drag and drop is a feature that I would really like to use a lot.
And I don't remember having read that Structure requires LE 7.3 for all of it's features to work.
Structure: No Drag and Drop?? gone in aax Rectifried AAX Plug-ins 10 11-08-2013 10:56 AM
Structure - next patch or only drag/drop? andrewpiano Virtual Instruments 5 05-18-2010 07:14 PM
Structure Database Drag & Drop filosofem Virtual Instruments 11 08-10-2009 08:38 PM
Structure Drag and Drop? Nope, not here... TimNielsen Virtual Instruments 12 05-20-2009 11:33 AM
Bug in Structure free drag and drop BR Rundfunk Virtual Instruments 0 02-10-2009 07:26 AM
