Old 06-21-2005, 07:50 AM
siggy siggy is offline
Default Recording into Pro Tools from Ableton Live
Does anyone know how to record directly from Ableton Live into Pro Tools? I am running PT 6.9 with a Rewire link to Ableton Live 4 DigiDesign Edition. I have drum loops loaded into Ableton, and I can play them fine along with the guitar/bass/vocal tracks that I have already recorded in PT.
Is there a way to record the drum loops from Ableton directly into the track in PT? Or do I have to record in Ableton first, then export to PT.
Any help/guidance appreciated! Thanks.
Old 06-21-2005, 08:10 AM
spkguitar's Avatar
Default Re: Recording into Pro Tools from Ableton Live
If you are running it rewired to an aux track, all you need to do is route the output of the aux track to a record enabled audio track using an available bus.
Old 07-20-2005, 07:17 AM
Thanks! Now I have good news & bad news. The good news is that I can get the drums from Ableton Live into the rewired AUX track, and I can hear them if the output of the AUX track is routed to the stereo output of Pro Tools. As soon as I route the AUX output via a bus to a record-enabled audio track, I can't hear anything. What have I missed?
Old 07-20-2005, 07:22 AM
spkguitar's Avatar
The input of your audio track is the same bus as the output of your aux track?
Are you in Input-Only mode or Auto-Input mode?
Old 07-20-2005, 08:07 AM
[Yes, AUX track output is Bus 3-4. Audio Track input is Bus 3-4.]
[Can you clarify? Not sure I understand this one.The problem seems to be somewhere between the AUX track and the Audio track.]
Thanks!
Old 07-20-2005, 08:23 AM
lemix's Avatar
lemix lemix is offline
siggy,
Seems that your routings are fine. To see and hear signal, one needs to monitor the incoming audio. That is "input monitoring". You'll find the two options under the Operations tab ; Auto input / Input only.
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
neeel neeel is offline
I have had the same issue with Reason while trying to do the same thing.
The way around it I found was to insert the rewire app on an audio track instead of a aux input track.
Trippy I know!
neeel.
MBOX MINI PTLE 8.0.3
MAC OSX Snow Leopard
Mac Mini 1.5Ghz Intel
2 Gig RAM
Old 07-20-2005, 07:46 PM
Problem solved! The Input Only Monitor did the trick. Thanks to you all for your help.
Ableton Live - performing/recording live w/HD3 Surth Pro Tools TDM Systems (Mac) 1 09-11-2006 04:50 AM
Pro Tools LE vs. Ableton Live 5 ccastillo123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-15-2005 11:11 AM
Recording w/Ableton Live slangification Pro Tools TDM Systems (Mac) 5 07-01-2004 09:24 AM
Recording Ableton Live in loop mode? wizdoom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2004 08:45 PM
Ableton Live and Pro Tools Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-08-2002 05:07 AM
