Old 01-14-2005, 09:32 AM
neomodo neomodo is offline
Default Volume Fader Time dealy problem
It is the strangest thing I tell you... all of the sudden there is a time delay whenever I change a volume setting in PT LE 6.4 - (Mbox) - Also it seems that sometimes even though I mute a track I still hear it playing. ANother thing that is happening is that sometimes when I stick an insert into a channel it kicks in ar max volume with everything clipping to the max. I'm perplexed about this... It is super annoying and problematic not to mention what it might do to my monitors, headphones or worse - my ear drums... Anyone have any ideas about this? Everything was working just fine until very recently.
Thanks!
Old 01-14-2005, 10:03 AM
Room24Prod Room24Prod is offline
Default Re: Volume Fader Time dealy problem
I've had the same problem, but only on certain sessions. Very inconsistent. But annoynig nevertheless.
Digi 002R Factory Bundle
P4 2.4 Ghz 1MB Cache
1GB PC3200 Dual-Channel DDR RAM
40GB HDD for OS
250GB HDD for Audio
(2) 17" Monitors
Old 01-14-2005, 07:00 PM
hey lookie there - I'm not insane .. : )
did you ever figure out what was going on?
Old 01-14-2005, 07:11 PM
SimpleNatureSpirit SimpleNatureSpirit is offline
If you have a high latency plugin on the audio track which has the volume automation, yes, the audio will be offset from the automation. It is better to send the audio to an aux and do the automation there. As for maxing volume, some plugins can be set to cummulate a lot of audio at certain times. Follow the chain and see if you have a lot of audio 'piling up'.
Share the gift gifted to you
Old 01-14-2005, 08:51 PM
steals steals is offline
I mentioned this before but got no response. I have the same problem with delay on volume faders but I'm not using any automation.
So how does one un-set plugs to not cummulate audio?
And what if the delay happens without plugs?
Joe Steals
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
volume fader in custom fader mode KimSira ICON & C|24 4 10-15-2008 09:54 PM
Track fader volume to send volume smmdrum Tips & Tricks 9 08-12-2008 05:22 PM
FADER MUD - IMPOSSIBLE TO MAKE FADER WRITES IN REAL TIME Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2007 10:34 AM
Fader volume problem MixMan1814 Pro Tools M-Powered (Win) 1 04-14-2007 11:05 AM
