Old 09-16-2004, 12:00 PM
samrisio samrisio is offline
Default wny does bus 1-2 never show up?
plug in choices always start at 4-5 and the first few choices are reverbs and such? and why cant i hear midi without record enabling the midi track? and why does the audio track record midi so low? questions questions...input output on audio and aux tracks are set to stereo 1 and 2..midi set to all channels and then out B from midisport which is where the sound module lives
Old 09-16-2004, 02:57 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: wny does bus 1-2 never show up?
Because you haven't set your monitoring from Auto Input to Input Only. Also, if you want to hear midi while playing, by rec enabling the track, you are telling protools which midi track you are playing.
Because whoever set up the system set up Bus 4-5 to be reverb by changing the name of the Bus in the I/O setups window. You should click the Default button in the I/O and everything should reset.
Sam, I told you this 15 posts of yours ago.
did you raise the volume of the Aux Track? Did you raise the volume of the sound module? Are you going in at +4 or -10? ( on the 002R), is the midi fader up?
questions questions
Its been several weeks that you're asking the same questions - and they IMO have all been answered. Follow the answers carefully and read the manual already.
Maybe if you give a detailed and clear explanation of everything you've done, a simple answer will fix it.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Loading show files in SHOW mode? fohluke VENUE Live Sound Systems 2 03-29-2012 11:46 AM
Pro Tools/D-Show standalone integration idea with D-Show show files/virt. soundcheck digidesigner VENUE Live Sound Systems 2 11-08-2011 02:52 PM
Avid at the 129th AES Show – Live Streaming from Avid Pre-Show Event Avid General 0 11-03-2010 09:16 PM
2.02 in a D show help!! MartyBee VENUE Live Sound Systems 9 05-30-2010 07:43 AM
tracked show vs. sequenced show AudioMajik VENUE Live Sound Systems 1 07-15-2006 04:40 AM
