Old 11-22-2022, 02:19 PM
OldFolkie OldFolkie is offline
Default Digi 002
All of a sudden my digi 002 has developed a problem where the faders don't respond on the mix screen when I mix by touch. However, they do respond when I grab them on the mix screen. They read automation fine but only from the mix screen. I'm using Pro Tools LE 8.5/Windows 7. It's worked fine up until today...any help out there? Thanks.
Old 11-22-2022, 06:14 PM
Default Re: Digi 002
You'll find many posts on DUC and elsewhere talking about skin contact issues (try licking your finger) and electrical connection between the cap and post (try testing with the cap removed). etc.
Search using Google not the DUC forum search. e.g.:
https://www.google.com/search?q=cont...not+responding
(see the Avid Knowledge Base article in the first few search results? You tried everything there?)
https://www.google.com/search?q=002+...3Aduc.avid.com
If it's more than that then get a used 002 or move to the modern era.
Old 11-26-2022, 04:12 PM
albee1952 albee1952 is online now
Indeed, assuming you still have the stock fader caps(plastic replacements won't work). Also remember that the 002 needs a solid ground on the AC plug(so if somebody cut off the ground pin, that would be a problem)
Lastly, though I have never seen this problem caused by the dreaded "power harness" issue, it might be worth removing the bottom panel(slowly) and re-seating all the harness connections a few times(working those connectors off and on a few times can scrape thru the oxidation build-up and restore good connection), just in case(if that does help, leave a note here in case it helps someone else).
Digi 002R as ADAT Slave to Digi 003R? Curdie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-01-2011 01:46 PM
Digi hardware - bizarre behavior - Digi you will lose this market share andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 02-26-2010 07:45 PM
Digi TS: Problem w/current Digi Core Audio Manager Armando Pro Tools TDM Systems (Mac) 4 10-11-2006 10:08 AM
Digi 002 vs Digi 002R W\Mackie Control Universal Lance Driskell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-28-2006 12:41 PM
Wha is the name of the digi cable to hook up Apogee digi 8+ card called??? leon777 Pro Tools TDM Systems (Mac) 4 04-15-2002 02:44 PM
