  #21
Old 11-13-2022, 01:19 PM
Top Jimmy's Avatar
Default Re: headphones and computer speakers
There’s a lot of poopooing going on in this thread in regards to ASIO4all. Oh come on! It’s perfectly adequate for on the road work with headphones and laptop speakers. It all comes down to what level of production one is attempting to accomplish.
The OP’s problem isn’t ASIO4all. It’s his expectation that it’ll switch from laptop speaker to headphone automatically because it worked that way in the past. The problem here is that he doesn’t understand how to use ASIO4all. I suggest he google up some videos on using ASIO4all so that he learns how to use it to switch outputs manually rather than expecting it to do it for him automatically.
James Cadwallader
  #22
Old 11-14-2022, 05:45 PM
DigitalDragon DigitalDragon is offline
i understand, So pro tools needs adjustment with asio control panel..i will seek more and see a difference soon. thanks.
  #23
Old 11-14-2022, 06:39 PM
Now i know what is going on but no direct answer on how to fix but thanks for advice.
  #24
Old 11-18-2022, 05:58 PM
hello Good evening.
i have audio interface. i will try out on sunday.
so we will see if thats the problem, remotely someone fixed the problem. my hp is changing setting when i shutdown i think. its not reading in playback engine the audio interface. i dont know why? find out on sunday.... if anyone knows please do tell. i really appreciate. thank you is it true hp give problems with pro tools?
  #25
Old 11-22-2022, 04:33 AM
Marcins94 Marcins94 is offline
Have you ever tried the AudioSwitch app? I am using now a prototype of an audio switch headphone stand, where there is an option to switch using hardware mode.
this helps me to keep my desk tidy and works during my gaming sessions too
  #26
Old 11-23-2022, 10:23 PM
all set audio interface not needed. thanks for help. ^^^wrong vocabulary jk...
  #27
Old 11-25-2022, 09:21 AM
i will have to see audio switch.
  #28
Old 12-03-2022, 04:37 AM
the problem was audio driver not set to proper setting realtek asio. need to be set correctly. and with audio interface you must manually change setting. so its done. thank you.
  #29
Old 12-15-2022, 07:12 AM
the problem came back. now headphones only work for computer when.manually set.running on speaker/headphones does not work. i dont know what to do next.
  #30
Old 12-15-2022, 08:50 AM
cwsand's Avatar
cwsand cwsand is offline
I would try what has already been suggested:
Originally Posted by nednednerb View Post
Check out Help Us Help You link at top of forum.
Originally Posted by albee1952 View Post
with all Windows setups, go into Sound Properties and make sure Windows is using the on-board sound card as its default playback device.
Originally Posted by The Weed View Post
Rent an interface and find out.
Also, although you did post some of your system info in your other post, make sure you post it here - the more info you provide, the better help you should receive.
It might also help if you could post a video showing exactly what you're experiencing.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Output going through speakers and not through headphones... gsmith38 Pro Tools | Intro Discussion 0 04-01-2019 02:55 PM
No output to headphones or speakers Lucky Bastard Pro Tools 11 5 04-19-2014 12:06 PM
All about Headphones/Speakers smrpg99 General Discussion 3 06-05-2011 02:16 PM
Playback of audio through computer speakers/headphones kheetah Windows 1 05-19-2011 02:39 PM
Speakers and headphones karlc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-30-2007 09:53 AM
