#21
Re: Plugin Reverbs vs Outboard Reverbs
Yes! Exactly! Naturally a fixed chamber has its own distinct sound, but that can be modified by many little tricks (some of which are used inversely by killing all reflections on control room) beginning with distance to mic a.k.a. "mix percentage".
#22
There isn't a plugin reverb which can match the best of hardware reverb.
Altiverb, even using the great IRs made by Acousticas, can't touch things like a TC6000 (the VSS4 algorithm. VSS3 is inferior to 4), or Lex 480/960/PCM96, or Bricasti, etc. Understand how something like the Bricasti works, from a technical standpoint, and you'll see how plugins simply can't compete. They will, eventually, because it's certainly possible, but they're not there yet. |
#23
its a multi-fx patch doing several things: reverb/ delay/ pitch shift/ chorus etc. I've yet to find a plugin that can do this stuff really well. the closest is probably Sound Blender from soundtoys and coincidentally thats the same team who were behind the Eventide Harmonizers. The biggest mistake Eventide made was calling them Harmonizers! as they have some of the best reverbs and delays ever and many people think they did just harmonizing. Eventide Factory plugin has many of the patches from the H3000 and the DSP range, but not many of the really mulit-fx one's. I also have a roland srv330, but if i take it out the rack there's going to be a big hole Chris
#24
I tested a Bricasti for a week and found it to be nothing special at all. As a matter of fact I was seriously disappointed by it after reading all the hype surrounding it. I tested it hard against the VSS3 plug-in and I like that a WHOLE lot more than the bricasti which I returned to the dealer. Then again, I like the acousticas EMT/LEXICON impulses a lot more than I like the VSS3. I dont think you can say that a hardware reverb is better than a software one, because they are BOTH digital. One residing in its own housing the other lending the housing from a mac or pc. Maybe a lexicon 480 impulse response does not sound exactly like the 480 hardware but the lexicon 480 impulse sure as H*** sounds better than the bricasti hardware...
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
#25
And digital vs. digital isn't an argument for or against hardware vs. software reverb. It's an issue of the quality of the algorithm and the available horsepower to accurately do the math, in real-time. The Bricasti, for instance, has a throughput of 3GB/sec. Think about that for a second (while the Bricasti processes 3GB... Your TDM chips are afraid of that number. As far as the algorithm goes, we're talking about some of the best minds in the business typing in the code. I'm not a Bricasti employee, and this isn't just about the Bricasti - it's about hardware reverb and their power and efficiency to do just one task. There isn't a single Acousticas IR which matches its hardware counterpart. Not one. VSS3 sounds very good, but it gives off a whiff of digital processing that I don't gravitate towards. Every plugin verb does so. The only exception I'd make to that rule is the Duende X-Verb, but then it's actually being processed by outboard DSPs and piped into the session via VST, so it's not really a plugin after all. |
#26
1) it is digital reverb 2) it uses DSP 3) it dithers/truncates its output to 24 bits 4) it is plugged in to the audio chain ...thus it is a plugin. Even external hardware (Lexicon PCM91 and such) can be considered being plugins when you use them via digital interface. Then it functions just like a plugin, only difference being it has dedicated controls available at all times.
#27
Impulse responses done carefully sound as the "sampled" original. But it's like with samples of real instruments: IRs are snapshots, not more or less. Kind regards Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
#28
I say, EMT 250 etc etc etc. How old are they? 30 years??? one of those 250 would probably fit 25 times on one tdm chip. It isn't at all about the horsepower its about the brains utilizing them. Quote:
#29
Not much work, guys? Who has time to argue the path of the DSP? If you really believe it, you should invest in it.
But I think your resources should be chasing a better song.
--Jeremy |
#30
Its a forum. Once goes here to discuss things. Even you
Outboard reverbs connected digitally above 48k? | crizdee | Pro Tools TDM Systems (Mac) | 13 | 02-16-2007 03:32 AM |
IR Reverbs | Larryboy | Pro Tools TDM Systems (Mac) | 0 | 04-04-2005 05:37 PM |
Reverbs? | JaredC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-09-2003 08:31 AM |
Outboard reverbs | ajazzie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 08-07-2002 08:13 PM |
Running outboard reverbs 'live' on mixdown (aux in) then what? Print it at 'the end'? | Jules | Tips & Tricks | 1 | 02-19-2000 05:01 AM |
