My friend and I have a debate giong on whos definition of Bar/Beat VS Absolute markers is correct when trying to paraphrase the manual.
My definition is: When you create a new Memory Location There are four time based options you must choose from 1. Bar|Beat (tick-based) its Markers diplay a Yellow Chevron. This marker will lock to a Bar Beat location and remain there as you change the tempo of the song. 2. Absolute which is (sample-based) and is represented by a Yellow diamond icon. This marker will remin fixed at the sample resolution Irregardless Of your tempo changes. His definition is: There are four time based options you must choose from 1. Bar|Beat (tick-based) its Markers diplay a Yellow Chevron. This marker will cause the playhead to jump to a defined memory loacation at the Bar Beat Resolution. 2. Absolute which is (sample-based) and is represented by a Yellow diamond icon. Will cause the playhead to jump to a user defined memory loacation at Sample resolution. Can anyone please help us out? |
The way I read you, you're both right but the first example is more correct. Absolute means just that. The bar/beat is relative. Set the marker and you'll return to that position in time, bar/beat and you return to the bar/beat wherever in time it may be.
To be clear: the markers don't move the playhead on their own. |
input latency offset recording - can we settle this once... | hollow | Pro Tools 11 | 4 | 07-15-2013 01:19 PM |
Off or on? Admin, please settle this for me? | ajazzie | ICON & C|24 | 1 | 07-25-2008 01:18 AM |
settle a bet! | your one guy | Pro Tools TDM Systems (Mac) | 13 | 11-29-2007 01:19 PM |
PLEASE SETTLE THIS: 001vs2408 | JMan | General Discussion | 8 | 11-05-1999 09:47 PM |
settle this please 001vs2408 | henryhill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-20-1999 01:49 PM |
