Old 01-30-2008, 12:48 PM
77pro 77pro is offline
Default BFD2
Was having stability problems whenever I ran bfd2....windows would close down protools whenever I opened it on an insert point and tried to do anything. Also crashed when it ran stand-alone. I e-mailed fx with the specifics and the logs generated when it crashed.
You can imagine my surprise when they e-mailed me back saying bfd2 is not supported with LE7.4 and XP home...I must be using XP pro. Their website clearly states under minimum requirements.." Windows XP SP1 or higher, Vista 32, P4 or better CPU" Also on the box I received with the BFD2 DVD's it says " Windows XP (SP 2 recommended ), Vista OSX10.4 or higher.
Anybody else having these issues?? Will have to see how this plays out before I get too irate...in the meantime it's back to Strike and the content expansion.
003r/i7-930/LE 8.0.1 cs2 on xp
Old 01-31-2008, 05:32 AM
waterbug waterbug is offline
Default Re: BFD2
77pro,
You’re not alone. I have experienced the same problem with BFD2. BFD2 looks to be much more complex then the initial BFD program. After I inserted the program on an instrument track, the program operated sluggishly, hung on occasion and then eventually crashed when I tried to play a groove. I checked their web page and found no help to resolving my problems. I never new that the program was incompatible with PT 7.4—interesting. Well, back to Strike.
Old 01-31-2008, 05:40 AM
Stig Eliassen's Avatar
Default Re: BFD2
I don't use BFD 2 (or BFD 1), but when Stylus RMX starts to get sluggish and quirky I delete the "Digidesign Databases" folders from all mounted drives.
Old 01-31-2008, 12:03 PM
Default Re: BFD2
Turns out when I sent in my initial report they misread "running on PT LE7.4" as "PT HD7.4" Big difference....HD needs XP pro , not LE. So now they can send my run logs to QC and see if they can find the problem.
I just noticed an update to ver. 2.0.2, dated today , I'll update and see what happens.
Looks like I'll be spending some time on the fx forum......
Old 01-31-2008, 02:01 PM
Default Re: BFD2
Upgraded to the latest version (2.0.2 b5) that was released this morning. So far, so good. No more crashes and it sounds excellent!!!
Do I need to buy BFD2 or BFD2 upgrade if I have BFD ECO? joedexter23 The Drum Room 26 07-23-2012 11:38 AM
BFD2 or BFD2 upgrade from BFD ECO?? joedexter23 Virtual Instruments 2 03-11-2012 12:42 PM
Bfd2 tommykoot Pro Tools M-Powered (Win) 1 11-03-2010 05:58 PM
BFD2 In PT 6.4.1 TDM DigitalMetal Pro Tools TDM Systems (Win) 2 11-13-2008 02:49 AM
BFD2 randyT Virtual Instruments 8 08-01-2008 12:41 AM
