Old 12-02-2021, 09:49 PM
EddieJones's Avatar
Default Re: S1 “key” commands not working
We checked this on S1 and its working here. I think it could be High Sierra. Apple changed things recently that caused us to have to use a different method for keyboard commands....I suspect its not supported in the older OSX's
Old 12-03-2021, 01:29 AM
globaleric globaleric is offline
Just noticed this thread, so for the record:
I'm on Mojave 10.4.6 , and those 4 "modifier" keys on the left of the S1 do not work here neither.
Not that I would dearly miss that particular feature: My Apple Magic keyboard is placed just in Front of the S1, so I'm reaching those modifier keys quicker on the keyboard anyway. Also, from my old Digi 002 I'm already somewhat used to the fact that not all available buttons on Digidesign/Avid control surfaces are working. (Sorry, couldn't resist!)
Nevertheless - Mojave is still supported with the latest PT release, so it would be cool if the same would apply to Eucon as well.
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD
Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins
PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder
Old 12-03-2021, 01:41 AM
andybhoy andybhoy is offline
Aw man. I’m the opposite - my fingers just reach for the command keys by themselves - dead handy for copy pasting or zoom in out n stuff.
To upgrade or not upgrade. That is the question! Risk plugs etc failing
Old 12-03-2021, 11:22 AM
EddieJones's Avatar
The Modifier keys can be confusing. There are two types, EUCON and Keyboard injection.
The EUCON ones get sent directly to the DAW, but the DAW has to support that. These ones support holding the key down.
Then there are the keyboard shortcut modifiers, these are to use with a keyboard shortcut/macro only, they do not hold down.
Old 12-03-2021, 11:27 AM
EddieJones's Avatar
x
Old 12-04-2021, 12:33 AM
Thx Eddie.
The most infuriating part in all this, is all I did is upgrade the software! It was working perfectly before that!
In my Eucon config there is a softkeys section. This used to hold down. So, this has been removed from the latest build?
Is there some way for me to actually get in touch with tech support? I’ve send requests but have had no reply. I’m now out my returns period for the S1 and Dock, but they’re not working correctly or I’d have sent them back.
As you’re right - this is all very confusing. Not sure why a working function, no longer works.
Old 12-04-2021, 09:27 AM
EddieJones's Avatar
Originally Posted by andybhoy View Post
Thx Eddie.
I'm the Product Manager/Designer for EUCON so you wont find better support
Are these the commands you refer to? Can you tell me which version they work in and which OSX version....did you update OSX at all? Is this with Cubase did you update that(what version)
Old 12-13-2021, 04:29 AM
Hi Eddie, apologies for the delay - I’ve been Ill. Thx v much for your help and patience!
It’s not actually commands - it’s just the soft keys - “key” as in Shift, Control etc. (as per images.)
The only thing I upgraded was the Eucon drivers. They previously worked fine until I upgraded. Version 10.5 Cubase.
File Type: jpg 34247EC8-E51A-463A-B448-D2DD7FABEDC3.jpg (54.2 KB, 0 views)
File Type: jpg FA6124CA-18E3-4A3F-90E2-67FFCFD9BB4C.jpg (52.0 KB, 0 views)
Old 12-14-2021, 07:46 AM
EddieJones's Avatar
Thanks for clarifying...I'll check out
Old 12-14-2021, 08:26 AM
EddieJones's Avatar
Are you sure this ever worked? Its the EUCON commands that should, there's are meant for modifying key commands and need other keys in the sequence.
Some key commands not working in PT 11.1.2 hakofred Pro Tools 11 2 02-05-2014 09:54 AM
Some new key commands not working K Roche Pro Tools 11 5 10-17-2013 06:01 AM
keyboard commands not working. Help! grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-21-2009 01:00 PM
Key Commands not working ? jjamesbomb Pro Tools TDM Systems (Mac) 0 01-25-2009 05:46 PM
"P" and ";" key commands not working 5.2.1LE... tadpole 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-12-2004 11:37 AM
