#21
Re: 2020.3 buggiest version in years
No and no.
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
#22
I can confirm that most of the issues that I am having are due to working with Video. As soon as I disable video everything runs smoothly. I tried a few different CODECS but with limited success. Dnx maybe felt better but I really can't say. I rolled back both systems to 2019.12 and all is fine with the world again. |
#23
thought I post an update on my bugs issues:
First, I did open 2 tickets with Avid, one of their suggestions solved my*Eucon issue... even though I do see that as a bug since that never was an issue before. By locking to Pro Tools in the assign tab I no longer get disconnects. Now to the VCA Coalasce issue: I figured out the cause and fortunately a work around: Only my drums VCA kept crashing, not matter what session... so I started digging more what is different between my drum VCA and my other VCA's. Turns out I had added the Drums basic folder track to the drum group associated to the VCA. So every time I do a coalesce it goes boom. Remove the folder track from the group and all is well again.... add it back and boom. So this is definitely a bug. 1 mystery solved don't add basic folder tracks to groups if they are part of VCA's Weird one... I wonder if that is because it does not have a fader
PT Ultimate 2021.10 Nuendo 10.3 Wavelab Pro 11 UAD Satellite Octo Thunderbolt, UAD Quad Pcie Apollo Twin Duo, HDX Card, 2x Avid I/O Analog 16/16, 4x Artist Mix, Avid Dock, PT Control, 2019 Mac Pro 12 core, 48 gig Ram, running Big Sur, lots of outboard gear |
#24
Bro ... Trust me the version is flawed ... I am running Mojave Here ... I rolled back to 2019.12 and couldn't be any happier !
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
#25
Since there was Catalina and 64-bit only, PT installer (2019.12 and later) installs differently on Catalina and the rest for obvious reasons. Made for Catalina so best judged used on Catalina.
#26
Anyone else having PTULT 2020.3 becoming nonresponsive when trying to import session data from V10 session?
#27
Any news on an update ? because it's not a good version
#28
You know, since you are on Mojave why not go back to 2019.5 which everyone thought was great..? You should already know that even 2019.12 that was initial compatibility release for Catalina is installing different PT for Catalina and other OS you might be using. Really comparing apples to oranges here if you don't run Catalina.
2020.3 working equally well here on Catalina (those video restrictions do not affect my workflow)
#29
The recall is fine. But when I insert the plugin, it crashes. Even with avid plugins. In particular, there are many problems with insert in DSP. I want you to solve the problem quickly.
#30
Probably dumb question but have you double-checked that *all* your plugins are latest version? Because if plugin A seems to crash your system and plugin B is outdated, the crash may still be plugin B related as every plugin you have in plugin folder is loaded in memory when PT starts.
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
2020.3 Mac 5,1 | stargazer | Pro Tools 2020 | 25 | 04-03-2020 02:54 PM |
New Avid Link 2020.1 - launched today 1/16/2020 | marianna | Licensing & Accounts | 8 | 01-16-2020 11:43 PM |
What happens after the four years of frre up grades in the acdemic version? | Abel0470 | Pro Tools 9 | 5 | 02-01-2011 09:18 PM |
is it me or is 7.1 the buggiest PT version ever? | WildHoney | Pro Tools TDM Systems (Mac) | 5 | 09-26-2006 09:45 PM |
