Solo-safing in AFL mode?
Recently set up AFL/PFL capabilities for my D-Command. Everything works as expected, though for some reason when AFL or PFL are enabled my fx returns mute when I solo a track.
For example, my whole mix is up and there is reverb on the vocal; but when I solo the vocal, the reverb is in turn muted. The obvious fix would be to 'solo-safe' the reverb send, one would think. Though while in AFL or PFL modes you cannot solo-safe tracks. When you hold command and click on the solo function, instead of graying out (typically indicating solo-safe functionality) the AFL/PFL volume fader pops up instead. Any ideas? |
Re: Solo-safing in AFL mode?
When using the AFL/PFL solo modes, only the channels soloed will play through this dedicated buss. So to hear the verb, it will also need to be soloed. It sounds to me like you want to just use the regular Solo In Place mode with your returns "safed" |
thanks as usual, dmaz. got everything in a working order at this point. i appreciate your expertise.
Happy you got it sorted. Glad to help.
AFL is needed when mixing "on air".
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
Solo mode bug or me? | Dallas Taylor | Post - Surround - Video | 10 | 09-27-2014 12:50 PM |
Slow Solo mode | T S | Artist Series | 2 | 02-24-2012 04:45 PM |
Solo Mode Setting not persisted in 2.6.2 | DhyanMikael | Artist Series | 0 | 01-06-2012 03:43 PM |
AFL Solo mode and solo trim | brenttrf | VENUE Live Sound Systems | 2 | 09-18-2010 12:44 AM |
Is there are new solo mode or am I doing it wrong? | derF | Pro Tools TDM Systems (Mac) | 6 | 03-02-2009 09:35 AM |
