Ok I am not enough of a drummer to say I play drums. I have a kit in my studio. Nothing special, it's a Pearl Forum series. The toms are 12", 13", and the floor is 16". I just put new batter and resonant heads on them and I'm tuning them. What is a good reference point for tuning them. I'm going nuts reading forums and YouTube etc. I'm ok using notes but what should I use. Any help would be greatly appreciated. I want them to be tuned for mixing them for recording only. Its never gonna leave my room. I'm finding I'm always to high or low and in 4ths apart the 12's to high or the 16's too low.
Thanks for any help Neil |
To each his own, but I've never deliberately tuned my drums to a specific note.
My thinking is that you want the drums, especially the toms, to stick out, often when everybody else is playing loud. If you're tuned to specific notes you'll just blend with the other instruments, which kinda defeats the purpose of providing emphasis and punctuation. Besides #1...If you're tuned to specific notes, what happens if the band is playing a song in a key that doesn't include those notes? Besides #2...I know, I know, harmonic rich and all that, but you can't tune your cymbals. I suppose you could take a grinder to them, but I'm sure not going to do it! Here's how I do it, YMMV... First, I consider the instrumentation of the band I'll be playing with, then try to put my drums into the holes in the sonic space that aren't occupied by other instruments. Typically this will result in the bass drum and low toms occupying the space above the bass guitar and below the rhythm instrument(s), such as rhythm guitar or keyboards. I'll then try to put my high toms just above the rhythm instruments. In order to accomplish these ends my drums are often tuned higher than the tunings most other drummers use. The tuning process... I usually start with the snare. I try to find the drum's resonant frequency, which is where the drum almost "sings", with a full and open tone. I'll then work with the snares to get the sharp "crack" sound that I prefer. Sometimes it's necessary to go a little bit above or below the resonant frequency to get the exact tone I want. I also check the tone with the snares off as I sometimes use the snare as an extra "tom", and I check rimshot and sideclick tone. I use a 20" bass drum, which by its nature gives me a higher tone than the 22"-ers that most guys use. Again, I start with the resonant frequency, then adjust to give me the exact tone I want. I somewhat "choke" my bass with a felt strip under the batter head. And as with my snare, I'm looking for a particular "crack". For the toms, I usually tune the high and low toms to their resonant frequencies, then space the other toms equally between those two. I tune the bottom heads either slightly lower or slightly higher, depending upon which tuning article I read the previous week. Again, to each his own...but I don't really obsess over my drum tuning. I want them to sound good, but I just don't want to spend my life in the often fruitless pursuit of some perfect tone. I'd rather spend the time to work on my technique. Hope this is useful...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while... ![]() Just rockin'...what more is there? Bill in Pittsburgh |
Good advice from Bill^^^. I would also search youtube(as great as Bill's explanation is, seeing it in practice can make a big difference). Be forewarned, not every drummer is good at it, so judge what you see on youtube. You may learn how to do it well, and you may also learn how NOT to do it
![]() BTW, if you have any drum VI, you might call up various samples and use them as a comparison(assuming they sound good to you) ![]()
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
![]() Quote:
Neil |
Tuning drums is a bit of an art. Try this and see if it helps you.
1) Low drums are harder to tune so start at the floor tom and work up. 2) Loosen the top head on the floor tom. Tighten the bolts directly across from each other finger tight (one bolt with your left hand; bolt straight across in your right hand). Move around the drum until they all finger tight. 3) Do the same on the bottom head. 4) Now turn each lug a half turn on the top and bottom head. If it's flappy sounding, turn them all an eighth turn more. Repeat until the flap is gone. Once you get a tone you like, and each drum will be different in each room, move to the mid tom and then the high tom. 5) Use the same process to tune the drums in thirds or fourths from each other. I often tune the toms and snare so they play an arpeggio (toms in thirds with snare a fourth above the high tom). The low tom note can be any pitch. You want the drums to be within their sweet spot. Whether that's C, D, or whatever in between doesn't matter. If this is something you'll need to do often, I recommend getting the DTS system for your toms. Your drums then tune like timpani and anyone can tune them. You then turn a single tuner to tighten the head much like a guitar tuner works to raise and lower the pitch of the string. The head stays in tune with itself. Kind of spendy but the system does work well. http://www.drumtech.com/dts.html http://www.youtube.com/watch?v=zvp_lTzv6gU Hope it helps. |
![]() Quote:
Neil |
Hey necjamc,
One resource I found a while back that has helped me out a ton is called the "Drum Tuning Bible" http://www.peabody.jhu.edu/data/46/link/3402/DTBv3.pdf Lots a great stuff in their, good luck! |
Real Traps (Bass Traps) Tuning a Room | Eddie D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-05-2004 11:40 AM |
Drum tuning | TLarvenz | Tips & Tricks | 9 | 05-09-2004 08:40 AM |
creating "real drum" ambience w/drum softsamplers | captain54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-02-2004 09:03 AM |
Real Time E-drum Problems | Randy Cobb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2001 08:34 PM |
CAN A DRUM MACHINE SOUND REAL? | TCN | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-07-2001 04:16 PM |
