Old 02-04-2014, 11:01 PM
Dizzi45Z Dizzi45Z is offline
Default Annoying Update automatically window.
I am on 10.8.5 and I have the latest version of Pro Tools 10 installed (10.3.8). I also have Pro Tools 11.1.1 installed on my machine and I don't want to go to 11.1.2 because of bugs I have heard about.
Every time I launch Pro Tools 10, I get the software update running and informing me that I have an update available. I have the "Do not check for updates automatically" checkbox checked, but it still launches every time I launch Pro Tools 10. It is annoying because their isn't an option on the window to just cancel, instead, I have to click details to close the window which launches my browser and etc.
Has anybody had this problem and found a way to fix it? Thanks.
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 02-05-2014, 01:20 AM
gugu gugu is offline
Default Re: Annoying Update automatically window.
Same issue here.
Old 02-05-2014, 01:57 AM
jojohamps jojohamps is offline
Same here on 10.8.5. Any ideas?
Old 02-05-2014, 02:00 AM
BasketCase BasketCase is offline
Same here!
I did a fresh 10.8.5 install yesterday - along with the latest versions of HD10 and HD11. HD10 keeps checking for updates on initiation, regardless of how the checkbox is.
Old 02-05-2014, 02:53 AM
Bruce Paine's Avatar
Bruce Paine Bruce Paine is offline
Admin Emeritus
Not sure how to fix this, but...
You can safely remove this file:
SoftwareUpdater.app
From this location:
/Applications/Avid/Pro Tools/
Just move it to a different location and see if that resolves the issue. If it does, then you can delete it entirely from your system.
If you subscribe to the Technical Alerts forum (either by RSS feed or forum subscribe), then you will still be notified whenever a newer version of Pro Tools is available.
Bruce Paine
System Details
Old 02-05-2014, 05:36 AM
SoftwareUpdater.app
From this location:
That's just one location; on my Mac there were two locations that I had to delete separately. And no, one was not an alias to the other. Spotlight found the other one.
Jack
QAPLA!
Old 02-05-2014, 03:13 PM
I moved both of the plug-ins.
One found:
The other found:
/Applications/Pro Tools/Contents/Applications/ (This one you get to by right clicking on the Pro Tools Application and choosing "Show Package Contents")
After I moved both of these to the desktop, it was still launching at start-up. However, once I put them in the Trash, it fixed the problem.
160 GB RAM
macOS 11.7.4
Old 02-05-2014, 03:45 PM
One found:
The other found:
As long as it's somewhere on a disk connected to a Mac it will be found. I never trusted update programs like this.
Jack
QAPLA!
Old 02-07-2014, 09:20 AM
al-andrew's Avatar
al-andrew al-andrew is offline
I used to have exactly the same problem, there is actually a tutorial in the help browser which explains everything you guys have mentioned ... Delete the app and clean out your trash 😇
Old 02-07-2014, 09:29 AM
al-andrew's Avatar
Hope this helps
Is there a way to automatically bring a track you select into view in the edit window Focuret Artist Series 4 01-05-2013 02:48 PM
Automatically play samples in the Audio Import window? daniel.yengle Pro Tools 9 4 05-31-2011 01:30 AM
Window should automatically scroll with Playback djbowyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-01-2010 09:40 PM
Annoying help window appears on everything. help! amptbuddy Pro Tools TDM Systems (Mac) 5 12-01-2006 10:00 PM
Edit Window advances automatically JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-26-2004 06:47 AM
