Old 05-23-2011, 06:54 PM
Omynys1 Omynys1 is offline
Default Expander/Gate Dyn 3
I thought this device functioned a lot different than I thought it would. Aparrently it raises the volume of the track reflective of the key input's volume as it passes threshold. I thought I was going to be able to disable audio for my gated track when the gate's key input was below threshold. I want a gate that does not effect(only disable) the timbre or volume of the track it is on.
I want the gate to disable audio when it's key input is not surpassing threshold.
NOTE : I've seen synth pads enabled only on drum hits. The gate was placed on the synth pads track and the gate's key input was the drum hits track.
Problem : The louder my gates key input bus gets, the louder my gated track gets.
c@n ! putz d@ 1nputz 1n my 0utputz█
Old 05-23-2011, 07:29 PM
Bill Denton Bill Denton is offline
Default Re: Expander/Gate Dyn 3
And the answer is...RTFM
The purpose of a gate is to "duck" the signal on one track when the signal level on another track exceeds the threshold.
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 05-23-2011, 07:31 PM
Sounds like you have settings wrong. Check for presets on the plugin as you want straight gating(with the sidechain triggering the threshold). Might be worth a look at youtube for some basics on gates
Old 05-24-2011, 05:43 AM
I watched the same four or five videos on there, but I'm not really seeing a straight gating feature on the Expander/Gate Dyn 3. I'm pretty sure that volume will always be reflected by the input's volume.
I'd like to see what kind of flavor i could create with just a straight gate though, if one does exist. I know I could very easily use volume automation to turn the track on or off, but I think triggering a gate to open with a wobble track could be much more flavorful.
Old 05-24-2011, 08:07 AM
Okay, after reading again, I think you are using the wrong plugin. If you want the sidechain signal to turn DOWN the audio of the track with the plugin, you should use the compressor plugin with the sidechain feed. With the gate plugin, the sidechain is causing the track to turn ON and you want it to turn OFF(or down). That is indeed called ducking and I do that with the compressor plugin. I use it for a talkback mic in the studio. The musicians to talk and be heard in all the headphone mixes, but as soon as the drummer starts playing, the compressor kicks in and lowers the mic by 20db so the leakage is not heard by everyone.
Old 05-25-2011, 06:39 AM
Someone on a different forum told me that this plugin is an expander and therefore that is what I am doing. A simple gate would mute/enable the volume, not cut/raise in scale to input.
Bug in Digirack Expander/Gate Roey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-16-2007 08:22 PM
C1 Expander / Gate Brandonx1 Pro Tools TDM Systems (Win) 2 10-01-2005 11:05 AM
Expander - Gate....anyone else notice this in 6.4? RBaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-04-2004 06:52 AM
Big Bug in PTLE Expander-Gate Charlie48 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-03-2002 02:34 PM
Digi-Rack Expander/Gate Toney Robinson Digidesign Hardware & Software 0 05-21-2001 11:58 AM
