Old 01-11-2011, 03:33 PM
ztaylor9632 ztaylor9632 is offline
Default Getting Audio to play from an imported MIDI track.
Well I am very new to PT LE... I do know that MIDI is not an audio track and I know how to get an midi track to work just fine with one i have recorded with my keyboard. I recently imported a midi file and it is not giving me the option for an insert. It is also not giving me the option to put the output to a bus...I know this is probably a simple fix but I have been reading the manual and messing with it for like 2 hours now so i figured I would ask you gurus on here what I am doing wrong
Thanks
Zak
Also I have a screenshot that i can email to you to show you what I am talking about...if need be.
Work Dammit!
GIGABYTE GA-X58A-UD3R 1366 socket
i7 950 3.06 ghz quad core
8 gig 3x2 OCZ gold triple channel
Radeon HD5750 RT 1 gig
Barrucuda 1 Terabyte 7200 RPM SATA 3.0 gb/s
WD Black 1 Terabyte 7200 RPM SATA 6.0 gb/s
OS-Win 7 Home Premium
Pro Tools LE 8.0.4/Mbox Mini 3rd Gen
Old 01-11-2011, 03:57 PM
DJ Hellfire DJ Hellfire is offline
Default Re: Getting Audio to play from an imported MIDI track.
Post the screen shot on Photobucket, because I have no idea what you are talking about. And also a video of your problem if possible.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 01-11-2011, 04:06 PM
Here is a short video explaining what I am talking about....
http://s1236.photobucket.com/albums/ff448/ztaylor9632/
Thanks for any input
Zak
Work Dammit!
Old 01-11-2011, 04:51 PM
Zak
In order to use midi tracks, you have to pair them with aux tracks and insert your instruments on the aux track. I prefer to just use instrument tracks. Uploading a pic of how to use midi!
Pro Tools 2021.12
Old 01-11-2011, 05:04 PM
Here's the screen print. Notice my midi track named Bass is followed by an aux track with a DB-33 inserted. Once you do this, set the output of that selected midi track to the DB-33 or instrument of your choice, and your midi notes will play through it. You have to set an aux track for each midi track. Then you can bus the aux track to an audio track if you choose.
http://s19.photobucket.com/albums/b1...oToolsMidi.png
Pro Tools 2021.12
Old 01-11-2011, 05:05 PM
I would create a stereo instrument track above or below the midi track. Highlight all the midi track and copy, then arrow up/down(the p or ; keys) and paste the midi onto the instrument track. Now you can insert the VI of your choice.(assuming you wish to use a VI).
Old 01-11-2011, 05:15 PM
Yeah, midi tracks suck!
Pro Tools 2021.12
Old 01-11-2011, 07:39 PM
thanks, makes a little more sense now, ill give that a shot!
Work Dammit!
Old 01-11-2011, 07:47 PM
yeah that worked like a charm...but like you said i quickly found out MIDI files suck!
Work Dammit!
Old 01-11-2011, 07:57 PM
danander11 danander11 is offline
Midi tracks are just fine..., when used as they should be..
You can send one set of midi to multiple instrument tracks at the same time, etc....
But they are for information only, not noise
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Imported Midi Files...Aux Track...I/O's whole note Tips & Tricks 5 06-27-2013 01:24 PM
How to get the tempo of an imported audio track? KGB2011 Pro Tools M-Powered (Win) 25 11-07-2009 07:08 AM
adjusting the tempo of an imported audio track erocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-02-2009 11:48 AM
Mute on audio track switches off when I play the track el biciclista Pro Tools TDM Systems (Mac) 3 07-29-2003 11:54 AM
matching imported audio to MIDI rygar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-13-2000 12:45 PM
