Old 03-02-2010, 12:53 AM
andrewcleaton andrewcleaton is offline
Default Send to Sibelius Not Working
Just upgraded to PTLE 8.03 on my 17" MBP - MacOS 10.5.8. I also run Sibelius 5.2.5.
I created a quick session - a few audio loops and some MIDI virtual instrument tracks - just to test everything out and explore the new plugs and AIR instruments. Hit "Send to Sibelius" and everything worked fine - there was my masterpiece beautifully scored and opened in Sibelius. No problem.
Then set to work on real project - no audio, just a load of MIDI VIs. I need a score for players so, once again, went to "Send To Sibelius" only to find the menu item greyed out. Not there - not an option! Looking at the Export Menu options, only MIDI is an available export option. Once again, the Sibelius option is greyed out.
I've opened a few other older sessions and none of them let me Send to Sibelius. Very frustrating as it's obviously worked before and I certainly can't think that I've changed anything.
Any ideas? Thanks.
Andrew
Old 03-02-2010, 02:22 AM
paulmellors paulmellors is offline
Default Re: Send to Sibelius Not Working
Not exactly sure on your specific problem, but would strongly recommend updating to Sibelius 6.
Fantastic improvements. Magnetic Layout is worth it on its' own.
Send To Sibelius definitely works with Sib 6 and PT 8, I use it very regularly.
Paul
[B]Pro Tools 2018.4, C|24, X32 Rack, Win 10, Waves 10, Komplete 11, composers collection
Old 03-02-2010, 05:19 AM
dmacintyre dmacintyre is offline
You need to open the score window first. Not a midi window in score view but the actual score window menu item. Until you do that it will remain greyed out.
Send to Sibelius problem philnicholl macOS 0 03-25-2011 03:29 AM
send to sibelius, export to sibelius... ericlees Pro Tools M-Powered (Win) 1 11-07-2010 08:17 PM
send to sibelius, export to sibelius... ericlees Pro Tools M-Powered (Mac) 1 11-07-2010 08:02 PM
Send to Sibelius danika Pro Tools M-Powered (Win) 1 03-14-2008 08:31 PM
pt 7.3 & "send to sibelius" command bradwarren Pro Tools M-Powered (Mac) 4 04-24-2007 10:03 AM
