Old 09-14-2002, 03:38 PM
jpd52 jpd52 is offline
Default 002 in TDM environment
Will the new 002 function if you move to a Mix Plus environment?
Jon
Old 09-15-2002, 04:57 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: 002 in TDM environment
do you mean if the sessions made in an 002 will be compatible with the mix or hd systems ???
of course they will.
Chris Lambrechts
Applications Specialist- Live Sound
Old 09-15-2002, 05:40 PM
JimWest JimWest is offline
Of course, 002 sessions at sampling rates greater than 48 kHz won't be compatible with Mix systems, which don't support higher sampling rates. (These sessions will be compato with PT HD systems.) You'd have to downsample your 88.2 or 96 kHz 002 sessions first before opening them on a Mix system.
As usual, you'll also have to have the same plug-ins on your "target" system as you had when you created the session the 002.
Jim West
Digi Engineering
Old 09-15-2002, 06:57 PM
oh right .... mix operates at maximum 48k .... already forgot about that .... [img]images/icons/shocked.gif[/img] [img]images/icons/shocked.gif[/img]
but even without the same plugins on the mix or HD system the 002 session will open .... the plugins will be deactivated.
Chris Lambrechts
Protools 10 Network Environment MBHS Windows 6 01-16-2013 08:51 AM
Recall a mix environment?? gabrieljay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-29-2009 07:09 PM
Vista environment . . . Vandy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-05-2009 11:35 AM
back and forth between MAC and WIN environment Jenk2k Storage Subsystems 3 10-26-2007 08:58 PM
Please,help me set up a recording environment for a singer. Kam Lion Tips & Tricks 2 05-26-2001 03:00 AM
