Old 01-14-2010, 01:17 PM
rbeggs rbeggs is offline
Default Focus strip erratic volume automation
D-Command. All faders except focus strip fader have smooth, consistent volume graph traces The focus strip fader will always render a jagged, inconsistent volume
trace. It is almost impossible to move the fader by any amount without getting
sharp, chattery 3-5 dB spikes regardless of which fader is assigned to the focus strip.
Is this a common problem or something that has been solved with an update?
Thanks,
rbeggs
Old 01-14-2010, 10:40 PM
trombino trombino is offline
Default Re: Focus strip erratic volume automation
The same fader when not being used as a focus channel is fine?
Mark
Old 01-15-2010, 10:54 AM
JKD99 JKD99 is offline
I've had intermittent trouble on my D-Control where the Focus Channel "lets go" of the fader it's controlling, possibly related?
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 01-15-2010, 12:58 PM
The focus fader (#24) is funky when not in focus mode as well. This leads me to think hardware is the villain. #23 has similar issues but it's unique problem is that often (not always), when moved, it shows no numerical incrementing in its readout and there is no automation written even though it's in touch mode.
For a few minutes all faders seemed fine but now hobgoblins are back. The symptoms are too erratic to be described accurately. As soon as a pattern is detected and some assumptions are made a new exception arises which creates yet more confusion.
For example: select fader #23 to be in focus mode. It is next to fader #24, the focus fader. I can move fader #24 and #23 will move in tandem however moving fader #23 will not cause #24 to move in tandem and there is no indication of incrementing volume in the fader #23 readout. Faders #24 and #24 also feel jerky and resist movement. Faders #24 and #20 work fine. They mirror each other perfectly.
This situation exists for about 10 minutes. I move on to other things, come back awhile later and faders #23 and #24 are fine but now faders #3 and #7 are not quite right.
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 12:12 PM
Feature request: Built-in De-esser via volume automation (strip sibliance!) AlexLakis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-12-2009 05:32 PM
Digi 002 fader automation is erratic Sadie Tango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-03-2008 06:07 PM
Digi-Strip Silence for Volume Drew Mazurek Pro Tools TDM Systems (Mac) 3 12-20-2003 03:45 PM
Automation erratic behavior nubus system Cabin Studios General Discussion 0 01-05-2001 10:22 AM
