Old 03-07-2009, 09:56 AM
GloryIsSilent GloryIsSilent is offline
Default Consolidation
What is the easiest/best way to consolidate a project for sending to another studio? I am using pt8 with an 003.
Old 03-07-2009, 10:02 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Consolidation
What do mean exactly?... Consolidating regions?..Sending a session via email?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 03-07-2009, 11:15 AM
Render each track starting at 0:00 with or without effects so it can be easily loaded into another daw or multitrack.
Old 03-07-2009, 11:27 AM
Phil Ogden Phil Ogden is offline
And export a MIDI file if there are tempo changes.
http://www.myspace.com/philogg
Old 03-07-2009, 11:28 AM
Well yeah its best (in most cases) to consolidate to 0 especially if u aren't going back to PT; U also, if ur done with editing, pocketing tracks, etc. to get rid of the extra playlist u aren't using; Make sure u delete all the Unused regions(which is something I do unconsciously throughout a session) IF u really want certain effects on tracks that u feel can't go without it, then re-record that track with it's effects but always leave the original; If u got VI's, u definitely wanna record those to an audio track & disable the instument tracks as well as track plug ins just in case the spot u go too doesn't have what u have Plug in wise; Name all ur tracks accordingly; if u make a Save Copy as, make sure u CHECK the all audio files option otherwise ur screwed on'eim; U may know most of this but I just trying not to leave anything out... If u drag the session to another drive make sure u open it up & change the disc allocation to the drive its on, close & re-open to be SURE... I think that may about get it...Anybody else?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 03-08-2009, 06:20 AM
help?
Old 03-08-2009, 06:55 AM
The above posts (yours included) have answered your question. There's no magic feature in PT that makes a universally acceptable session format. The nearest is OMF, but it requires add-on PT software (DigiTranslator) and is far from reliable.
Old 03-08-2009, 08:54 AM
Originally Posted by GloryIsSilent View Post
help?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 03-08-2009, 09:02 AM
So there's no way to export a multiple tracks at once in PT?!
That seems incredibly strange considering most every other DAW I've used can do this easily.
Old 03-08-2009, 09:12 AM
You can use 'Export Regions as Files' from the regions bin (drop down menu). This will do multiple exports simultaneously but they won't have any RTAS processing applied and you'll have to consolidate to full track length first.
Fades on Consolidation sszeryk Tips & Tricks 2 05-20-2010 09:47 AM
Consolidation? Rome630 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-18-2006 06:26 PM
Track consolidation bug? Jaysus Pro Tools TDM Systems (Mac) 5 04-30-2006 11:35 AM
consolidation ? jata Pro Tools TDM Systems (Mac) 6 10-16-2005 12:24 PM
consolidation sid rosen Tips & Tricks 2 11-12-2004 12:28 AM
