Old 03-01-2009, 11:57 PM
krop015 krop015 is offline
Default Plugins taking forever to load
This is my second attempt in hopes anyone knows a solution..
I am on PT8 HD and when i initialize a plugin (such as waves SSLchannel) it will give me the beach ball of death for about 20-35 seconds then the plugin will load. I am having this problem with about 10 or 15 of my most used plugins. It makes it extremely difficult to run fast easy sessions. I have done everything i could think of (trashing prefs, re-installing PT/Plugins) and i have no luck.
The one hint i have is that when i choose the plugin on an insert while the beach ball is spinning the system drive starts spinning very fast (like it is looking for something)
Thanks in advance.
Old 03-02-2009, 01:47 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Plugins taking forever to load
Thanks in advance.
The only thing i have ever known to slow dow the loading of a plugin is a slow hard drive or a hard drive that is close to full.
Do you have any USB drives connected? this slows down the loading of plugs? as will USB sticks and some MP3 players
Is your system drive getting full? ideally you need 30-40 gig free and you need to keep it in good shape. repair permissions or rebuild the drive using disk warrior.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-02-2009, 05:43 AM
TAFF TAFF is offline
I'm having the same problem and I think it';s a PPC thing? We've got 3 systems running PT8 ranging from a Dual 2ghz to a Quad 2.5 and they are all slow. Even with a new install on a brand new SATA drive the plugins are slow to boot up. I've got 160gig free on my new system drive with 4gigs of RAM. Still sluggish
Paul McFadden
Old 03-02-2009, 06:23 AM
Reckless Erik Reckless Erik is offline
You may also delete the Waves cache folder. Had terrible problems with waves plugins after I updated the OS. Once I deleted the cache file folder for Waves everything ran smooth again.
Nick
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2024.10.1 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2024.10.1 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 09-08-2010, 11:32 PM
BigEvil BigEvil is offline
Deleting Waves Cache folder worked for me. Could be coincidental but many of my plugins load much faster and smoother now.
Old 09-09-2010, 02:04 AM
GS-DK GS-DK is offline
Could you please tell me where I can find the Waves cache folder. Is it the Waves folder in the "Library" - "Cache" - "Waves" - "Applications" - "Waves" - "Waves Plug-Ins"? I have different bundles there.....Ane risk of getting into trouble if I erase them?
Thanks!
Old 09-09-2010, 04:40 AM
Hanswurstlsepp Hanswurstlsepp is offline
I found this thread:
http://duc.digidesign.com/showthread.php?t=259286
There it says:
delete the Waves Caches folder located at: System Hard-Drive> Users> Current User> Library>Caches>Waves
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2024.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 09-18-2010, 10:18 AM
psycho_monkey psycho_monkey is offline
Is it only waves?
Randomly, I had a similar issue recently where certain waves plugs (including the SSL channel) refused to load. Others were fine, as was every other plugin on my iLok. Spinning ball then PT stopped responding.
I traced it down to my audio drive having issues. I have no idea why that should be the case, but if you can't fix it by clearing cache etc, try removing every drive except your system drive, then trying again.
PT 10 Taking Forever To Open Tulane Sound Windows 10 10-31-2011 10:55 PM
Structure Free is taking forever to browse & load up samples QPro5-AM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-02-2010 07:32 AM
Loading PT8 taking forever.... mholley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-06-2009 12:45 PM
Plugins taking forever to load krop015 Pro Tools TDM Systems (Mac) 0 02-04-2009 04:13 PM
6.9 taking *forever* to load session sonicblue57 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-31-2006 01:17 AM
