Old 08-10-2008, 09:45 PM
katooo katooo is offline
Default Beginner with MIDI - Please Help!
Hello all,
I just invested in an mbox 2 factory and I am relatively new to pro tools.
i would like to use an old yamaha keyboard (SY22) to input midi.
i have connected it to the MIDI input/outputs on my mbox using 2 MIDI cables and using the manual I have set up a new midi device in the AMS window through protools, choosing Yamaha SY22 and connecting its input and outputs to the mbox icon.
when i record enable my midi track i am unable to get any signal.
i am sure it is a simple problem, does anyone have any ideas on where i am going wrong?
i am running it on a macbook running leopard 10.5.3 and pro tools 7.4.2.
thank you for your help!
Old 08-11-2008, 10:03 AM
DigiTechSupt's Avatar
Default
Do you have MIDI Thru enabled under the Options menu?
Avid Audio Tech Support
Support FAQ
Old 08-11-2008, 01:02 PM
gdugan gdugan is offline
Default
Originally Posted by DigiTechSupt View Post
Do you have MIDI Thru enabled under the MIDI menu?
I think DigiTechSupt meant under the Options menu.
Old 08-11-2008, 01:26 PM
Default
You are correct, sir!
Edited my post to correct that mistake...
Support FAQ
Old 08-11-2008, 03:03 PM
Default
Hi there, thanks for reading,
yes midi thru has a tick next to it and still no luck, any other ideas?
Old 08-12-2008, 04:55 AM
Dutchmountain Dutchmountain is offline
Default
Does your Yamaha Keyboard show up as an input device ?
Setup => Midi => input devices Make sure it's ticked..
Dutchmountain
Artist Mix, Artist Mc Control, Pro Tools, Cubase, Imac 27”
Old 08-12-2008, 04:51 PM
Default
hi there dutch mountain
yes Yahama SY22 is the only one there and it has a tick next to it. Any other ideas?
Old 08-12-2008, 05:41 PM
Default
Can you download and run MIDI Monitor and tell me if it shows any incoming MIDI data when you play your keyboard?
http://www.snoize.com/MIDIMonitor/
Support FAQ
Old 08-12-2008, 07:47 PM
Default
Hi everyone, problem fixed!! wasnt an issue with pro tools it was a problem with my yamaha SY22 - had a read of its manual and turns out midi wasnt turned on on it properly !!! thanks for your help!
Old 10-06-2008, 08:28 PM
garfield mead garfield mead is offline
Question Re: Beginner with MIDI - Please Help!
Hey every one im using my asr10 keyboard as a midi controller, motu mtpav with 4 different sound moduals recording to protools 7.4 hd 192i/o. Im able to record fine but was wondering if it is possible to change and view the patch list for each modual with out using that keyboard mouse. Just asking because i was able to do this in logic ....oh well.
MIDI INTO PROTOOLS BEGINNER HELP outtareach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2007 11:10 PM
beginner MIDI how 2? billymc MIDI 4 03-28-2006 08:56 AM
Midi Beginner Help Please jah-d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-13-2004 05:09 AM
MIDI beginner... help please! twanster MIDI 0 02-05-2004 01:00 PM
midi beginner sweeno MIDI 0 12-09-2002 08:28 AM
