Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 10-24-2007, 08:03 AM
Jenk2k Jenk2k is offline
Default back and forth between MAC and WIN environment
I work in WXP, LE 7.3 and need to take sessions to the big studio in 7.1 and they need to work on MACs. I use an external firewire drive that is formatted in NTFS.
Should I partition this drive in any way to make my sessions readable for the MAC environment? If so, would I save versions on ther MAC section of the drive before taking the sessions into the 'big' studio?
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002)
Old 10-24-2007, 08:51 AM
DigiTechSupt's Avatar
Default Re: back and forth between MAC and WIN environment
The Mac will be able to read that drive - all you need to do before opening the session is copy the session and all the audio files to a local, Mac-formatted drive.
Avid Audio Tech Support
Support FAQ
Old 10-24-2007, 02:27 PM
I don't want the sesions moving to their drives unless there is a technical reason to do so. I want the work to be done on my drive and my drive only.
I've already tried this and the MAC would read the drive, but as read-only. I was able to copy the sessions over and work in them on his root drive. I also need to be able to take those sessions out fo the studio with drums on them and work on them at home. .
In order to accomplish this, should i reformat the drive half mac half win, and just copy the session back and forth between the two partitions?
Old 10-26-2007, 08:58 PM
Craig F Craig F is offline
PT on the PC can use Mac HFS+ drives if you have the right software
no push/pull needed
no multi partitions needed
Thank you,
Craig
Protools 10 Network Environment MBHS Windows 6 01-16-2013 08:51 AM
Recall a mix environment?? gabrieljay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-29-2009 07:09 PM
Vista environment . . . Vandy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-05-2009 11:35 AM
going from studio to live environment jlee462 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-04-2003 12:12 PM
002 in TDM environment jpd52 Pro Tools TDM Systems (Mac) 3 09-15-2002 06:57 PM
