Old 03-24-2005, 09:35 AM
macD macD is offline
Default Options for G3
I'm new to PT and recording and wanted to get a very basic set up going for home use...
What are my options, using a G3?
I'm assuming the Mbox or used Digi 001 are good starting points?
Old 03-24-2005, 09:48 AM
maccool maccool is offline
Default Re: Options for G3
What kind of G3?
Dual 2.0 G5, 10.4.6, PTLE 7.1, 002R
Old 03-24-2005, 09:51 AM
Reb Reb is offline
Some G3's are not supported with the Mbox (check the compatibility section). You could probably use a Digi 001 though or a mix system if you have a g3 tower and want to look on ebay for used stuff. The Digi 001 would be cheaper. The other route that you can take is to use the G3 as a sampler/synth module setup and purchase a mac mini or imac g5 with which you could use the mbox or digi 002r.
Old 03-24-2005, 09:54 AM
DJ Insomaniac DJ Insomaniac is offline
Well, if memory serves correctly, ProTools 6 is not supported on G3 systems (i'm assuming that you're refferring to the Blue & White model). Because of the PCI graphics card, it just won't work.
Your best bet would be a Digi 001 running 5.1.1 (with the Beta 32 upgrade, allowing 32 tracks) or an Mbox running 5.2.1.
Another option (probably not what you're looking for) would be to get a new computer and use the G3 as a file server or "other stuff" computer, like online work. A Mac Mini would do.
Good luck, let us know how it goes.
Sam Ejnes
Re-recording Mixer
samejnes.com | IMDb | Analog Jitter
Currently using 7.1.1 on 10.4.11, what are my options? Sixpence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-08-2008 12:59 PM
where is my mp3 options nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2007 05:47 PM
7.0 plus options skwad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-13-2005 05:26 PM
mix to pic options with LE/002 DARCsound Post - Surround - Video 2 06-30-2004 09:54 AM
HELP WITH MIX OPTIONS Pro Tools TDM Systems (Mac) 0 01-31-2000 11:52 PM
