Old 06-28-2004, 02:44 PM
DARCsound DARCsound is offline
Default mix to pic options with LE/002
I am current owner of G4 / TDM Mix 24, 888 I/O, USD - using Machine Control to lock up video pix cuts on a video deck to mix to pic. Potentially, we'd like to shift to G5 / 002 / PT LE w/ DV toolkit (rather than HD upgrade path, although I know its a good deal!). My question is, what are the options for mixing to picture and being frame accurate? The video side of the post house is using G5 / FCP HD / Aja & other high end cards...
I know that my current TDM system can import a qtime movie, but for hour long shows the playback is slow, choppy (even on separate drive) and takes extra step for video editors to compress & reassemble long movie in QT.
With a new G5 / 002 / PT LE, what are my choices for locking to picture (internally via QT or other method, or externally to a deck)? Is anyone using Firewire to control a DVCAM deck and locking it to the PTools timeline? Any other workflow options?
Also, I'm assuming I can export OMF (or AAF?) from FCP HD and import OMF (or AAF?) to PT LE w/ DVToolkit - without haveing to buy Digitranslator, as I'm faced with now in my current set-up TDM 24 Mix?
Any advice or feedback greatly apprecciated.
Thanks.
Darryl
Old 06-29-2004, 11:45 PM
philper philper is offline
Default Re: mix to pic options with LE/002
DV Toolkit includes Digitranslator 2, and it works quite well.
Philip Perkins CAS
Old 06-30-2004, 09:54 AM
steppenwolf68 steppenwolf68 is offline
I use the Canopus ADC 100 for capturing video and also for outputting video to an external monitor.
Works perfect except if you do a lot of scrubbing.
Just make sure that timecode is displayed on the picture so you can properly align the movie in Pro Tools. Or if you get a Quicktime movie from FCP make sure TC is already burned in.
Omf export from FCP should work fine with OMF Tool.
I haven't tried it yet but Gallery has released a tool for Pro Tools to capture via 9-pin machine control. So there you go...
http://www.digidesign.com/diginews/2...04/gallery.cfm
Cheers
Peter
HTML code is On
Currently using 7.1.1 on 10.4.11, what are my options? Sixpence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-08-2008 12:59 PM
where is my mp3 options nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2007 05:47 PM
7.0 plus options skwad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-13-2005 05:26 PM
Options for G3 macD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2005 09:54 AM
HELP WITH MIX OPTIONS Pro Tools TDM Systems (Mac) 0 01-31-2000 11:52 PM
