Old 03-13-2004, 01:59 AM
jah-d jah-d is offline
Default Midi Beginner Help Please
Hi, I am trying to use Kontakt via RTAS. But it seems Pro Tools won't see the Midi keyboard. So I open Audio Midi setup, I see Digi02 Icon. I tried test setup, If I play keyboard,I could hear beep sound through internal output.
The "MIDI IN " light on Digi02R is flashing.
How can I setup Midi keyboard.
My setup
G5 1.8DP
OS10.3.2 DIGI02R
Pro Tools 6.2.3 Ozone Midi Keyboard connect via Midi cable
Old 03-13-2004, 02:51 AM
mersisblue mersisblue is offline
Default Re: Midi Beginner Help Please
this is how its done
enter midi studio setup create new device name it
then open more options or what ever and select all channels mtc the works regardless
then connect the cables virtually and in reality
close midi set up
open midi bar enable midi thru , beat clock if needed ( not in your case ) \
make a audio track put kontak on it select the correct midi channel input '
you may have to load the plug with a sound first record enable
thats it
i think i got it all anyway
Old 03-13-2004, 05:09 AM
mindnoise mindnoise is offline
if you want to record from Kontakt, NI suggest to insert Kontakt in an AUX track and then use a SEND/Output bus to an AUDIO track.
regs
last: PT11.3.1
Beginner with MIDI - Please Help! katooo MIDI 9 10-06-2008 08:28 PM
MIDI INTO PROTOOLS BEGINNER HELP outtareach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2007 11:10 PM
beginner MIDI how 2? billymc MIDI 4 03-28-2006 08:56 AM
MIDI beginner... help please! twanster MIDI 0 02-05-2004 01:00 PM
midi beginner sweeno MIDI 0 12-09-2002 08:28 AM
