Old 08-04-2021, 11:00 AM
EddieJones's Avatar
Default Re: Open PI preset from surface
I put off Plugin Instantiation, Preset Recall and I/O patching (all the same thing) on S6 because I wanted to improve on what we have(scrolling through with the knob) on the older EUCON surfaces. Unfortunately the way I want to do it(in a more graphical way, using the S6 screen) turned out to be a lot larger task than originally thought, so got postponed.
It is still high on the list but we are working on Swap Layers and the Assignable Knob at the moment as these are controls not programed yet, plus an increase in performance. I hope to get to it after the next release.
Old 08-04-2021, 02:54 PM
basehead617 basehead617 is offline
An elegant touch screen method for instantiation would be nice for sure but I do think there's also benefit to being able to do it on the surface on the channel strip, especially if the scrolling list adheres to the plugin type folders instead of being 1 big list (e.g. you push into EQ and it shows the EQs).. both would be ideal..
Old 08-13-2021, 12:14 PM
creativecontrol's Avatar
Performance!
Originally Posted by eddiejones View Post
i put off plugin instantiation, preset recall and i/o patching (all the same thing) on s6 because i wanted to improve on what we have(scrolling through with the knob) on the older eucon surfaces. Unfortunately the way i want to do it(in a more graphical way, using the s6 screen) turned out to be a lot larger task than originally thought, so got postponed.
It is still high on the list but we are working on swap layers and the assignable knob at the moment as these are controls not programed yet, plus an increase in performance. I hope to get to it after the next release.
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-13-2021, 03:55 PM
EddieJones's Avatar
Originally Posted by creativecontrol View Post
Performance!
v2021.10
Old 08-13-2021, 05:42 PM
v2021.10
That’s soon!
Old 10-04-2021, 01:40 PM
v2021.10
Assuming this was not a joke will you have info on this soon?
Old 10-04-2021, 02:15 PM
EddieJones's Avatar
We are still on track for the end of this month.
Old 12-17-2021, 04:29 PM
Hi Eddie, is plugin management and assignable knob on tap for the next release?
Old 12-17-2021, 04:45 PM
EddieJones's Avatar
Soon but not the next release. We got the Swap and the performance in the last release and the assignable knob in the next.....then maybe.....
Old 04-25-2022, 03:09 AM
Alright swap and assignable knob stuff is all done (both great stuff), now’s the time for plug-in/preset management! :)
Digi? will C24 ever work again+preset window open? crizdee ICON & C|24 1 04-18-2006 10:22 AM
Command 8 unavailable when preset dialogue open!!? crizdee ProControl, Control|24, Command|8 0 04-21-2005 08:36 AM
The Protools Plugin Preset Co-op is open! tld General Discussion 11 09-25-2000 09:16 AM
The Protools Plugin Preset Co-op is open! tld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2000 09:08 AM
The Protools Plugin Preset Co-op is open! tld Tips & Tricks 0 09-22-2000 09:07 AM
