Old 05-04-2022, 08:06 AM
audiogamble audiogamble is offline
Default Re: Aux Sends Causing High CPU Usage - Pro Tools 2021.6 and Higher With Apple Silicon
Avid has assigned a bug # to this. PT-286348 . Hopefully we see a fix in upcoming versions.
Old 05-04-2022, 10:18 AM
Thanks for finding this, and reporting it, just so important with the transition to Apple silicon!
Old 05-17-2022, 10:05 PM
studiorat67 studiorat67 is offline
Default Re: Aux Sends causing high CPU usage PT 2021.6/higher with Apple Silicon [PT-286348]
Tested Here 2018 MBP 2.9 GHz 6-Core Intel Core i9
32 GB 2400 MHz DDR4, Radeon Pro 560X 4 GB
Normal conditions this Version of Protools has been Very Unstable with My Normal use 100 Tracks plus Processing on a Template with 60 Auxes....CPU Spikes 100% Frequently and Freezes with Random GUI Graphics Issues and Lots of Fan Usage....But This test ...
All 10 busses upon 121 Tracks of included audio... and purring along like a champ with 15% cpu playing 121 tracks of audio includes Busses
I furthered the insult to injury added 131 instances of Slate VMR on all Mono and stereo audio and bussing, It Jumped up 96% and then froze up So I added 5 More instances per track and PT was a pinwheel Pinned at 100% CPU usage non responsive And Gasping for life..so I made slate inactive across 60 Tracks and Cpu Usage dropped to 67% Dumped all Slate and CPU Dropped to 13% and held steady for 20 minutes on loop
What I Run Daily
IMAC HIGH SIERRA 10.13.6 PT 11 STUDIO A
MACBOOK PRO I-9 1TB SSD 32 GB RAM, PRO TOOLS 2018, STUDIO B
MAC G5 YOSEMITE, AVIDS 192'S WITH PRO TOOLS 10 STUDIO C
MAC PRO 12 CORE 64 GB RAM 2TB SSD PRO TOOLS ULTIMATE STUDIO D
Old 05-25-2022, 09:54 AM
jeffro's Avatar
jeffro jeffro is offline
We are testing a fix for this and will update this thread when we have more info.
linkedin
Old 05-26-2022, 09:43 AM
jeffro's Avatar
Okay, anyone experiencing this please check in v2022.5 and report back when able. Thank you!
avid.secure.force.com/pkb/articles/Download/Pro-Tools-2022-5-Release-Info
linkedin
  #16
Old 05-26-2022, 10:36 AM
persen persen is offline
I am downloading know and am gonna check with the sends stress test at once
MacBook Pro M1 (13-inch, 2020)
16 GB RAM
PRO TOOLS STUDIO 2022.5
UAD Apollo 8p + Twin Solo + Octo Satellite
  #17
Old 05-26-2022, 10:45 AM
Great news from here!
120 tracks with all ten sends on when playing only increases totall cpu by 3-4 % compared to maxing out on 100% and giving the CPU error on version 2022.4.
Great work !!!
Persen
16 GB RAM
  #18
Old 05-26-2022, 12:34 PM
So far so good over here!
I noticed that the "windowserver" process on mac seems to be working a bit harder than before. As far as PT performance goes, all my most demanding sessions opened up for me with no problems. GUI nice and snappy on first glance. No CPU errors where I was getting tons before. So far so good!
  #19
Old 05-26-2022, 12:55 PM
Carl Lie Carl Lie is offline
This good news. Thanks Avid for fixing!!!
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #20
Old 05-31-2022, 07:51 PM
Phil O'Keefe Phil O'Keefe is offline
I just tried audiogamble's test session again using 2022.5.
I still have my notes from when I tried it with the previous version of Pro Tools. It topped out at 9 aux sends and 87-96% CPU use. I received an AAE 9173 error whenever I tried it with the 10th aux enabled.
With the latest version (2022.5) of Pro Tools, I was able to activate all ten aux sends and run the session flawlessly, with the system CPU use showing 14-15%. I was using the M1 Max Mac Studio listed in my sig. The only other change since I ran the initial test was a macOS update from 12.3.1 to 12.4.
This was a significant bug, but based on my tests, it's fixed now.
Thank you, Avid.
PS I was obviously wrong when I recently posted in a discussion about this bug that you don't appear to be that concerned about bug fixes lately. At least in this case, you obviously were, and I was wrong. My apologies, and thanks again!
Phil O'Keefe
PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
2022 PT and M1 Apple Silicon glasswing Pro Tools 11 04-30-2022 05:31 PM
Advice for P Tools HDX & Apple Silicon glasswing Pro Tools 28 04-23-2022 08:50 AM
More Apple Silicon misery Leon77 Pro Tools 2 06-23-2021 03:23 AM
High Memory Usage - PT 2021.3 Paulienat Pro Tools 14 04-08-2021 04:54 AM
