Hi, how I do to choice bit rate of project in PT first if possible, I searched but I didn't find anything, thanks for help...
When you are creating the session you can change the bit rate. To change the bit rate of an old session you have to save a new copy (File>Save Copy In) but I'm not sure that is available in PTFirst
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Thanks, but there is not options to choice or change bit rate when creating new session, and the default is 32bit
Must be a PTF thing, anyways you can't go wrong with 32bit.
Pro Tools First is 32 bit only. Higher versions of Pro Tools allow you to select different bit depths when creating projects.
Ok thanks!
But there is no mp3 Bit Rate control in PT. ACX need Bit Rate (not bit depth) of 192kbps or higher. help :)
Bit Rate / Sample rate | supersam83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2010 08:55 PM |
auto matching pull factors + frame rate + timecode rate | Dingo90 | Post - Surround - Video | 1 | 10-17-2009 04:16 AM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
mp3 bit rate question 128 / 320 ? constant bit rate | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-04-2008 02:07 AM |
QT 23.98 video frame rate... timecode rate? | dopplah | Post - Surround - Video | 10 | 07-03-2007 05:28 PM |
